Special TUNERZ STORE | Fortune Auto 500 Series Coilovers - G37 Coupe & Sedan RWD/AWD
#57
All coilovers will get the Gen 6 upgrades...
35% greater range of damping adjustment
Generation 6 models benefit from an upgraded jetting assembly. In previous generations the orifice bleed holes were hand drilled. Generation 6 bleed holes are now CNC machined allowing for more consistent damping adjustments between shocks. Furthermore flow of the orifice bleed holes has increased and a re-designed jetting assembly is used, this yields a 35% increase in damping force adjustment. Providing the user with a shock that has more performance and adjustability.
Revised CNC machined components
New CNC machined adjustment ***** replace the outgoing cast molded *****. These new machined adjustment ***** are hard anodized and more aesthetically pleasing. Updated shaft end caps are now lighter and showcase a more elegant design.
