Special TUNERZ STORE | TEIN Basis Coilover Kit - 07-08 G35 Sedan, 08+ G37 Coupe/Sedan
Old Jun 26, 2017 | 10:31 AM
  #91
Tunerz_Store's Avatar
Tunerz_Store
Parts Specialist
PM me for your best deal on any item we offer!
Old Jul 16, 2017 | 10:34 PM
  #92
Tunerz_Store
Parts Specialist
PM me for the best prices!
Old Jul 26, 2017 | 11:19 AM
  #93
Tunerz_Store
Parts Specialist
All PM's replied. Thank you for your business everyone.
Old Aug 2, 2017 | 11:04 AM
  #94
Tunerz_Store
Parts Specialist
Thanks for the orders!
Old Aug 22, 2017 | 07:43 PM
  #95
Tunerz_Store
Parts Specialist
Thanks for the continued support!
Old Sep 2, 2017 | 10:10 PM
  #96
Tunerz_Store
Parts Specialist
Old Sep 10, 2017 | 12:41 PM
  #97
Tunerz_Store
Parts Specialist
Old Sep 15, 2017 | 07:08 PM
  #98
Tunerz_Store
Parts Specialist
Old Sep 29, 2017 | 08:36 PM
  #99
Tunerz_Store
Parts Specialist
Old Oct 1, 2017 | 09:44 PM
  #100
Tunerz_Store
Parts Specialist
All pm's replied.
Old Oct 3, 2017 | 12:28 AM
  #101
Tunerz_Store
Parts Specialist
Old Nov 7, 2017 | 02:25 PM
  #102
Tunerz_Store
Parts Specialist
Old Nov 28, 2017 | 12:25 PM
  #103
Tunerz_Store
Parts Specialist
Best Deals every day!
Old Dec 4, 2017 | 09:30 PM
  #104
Tunerz_Store
Parts Specialist
Old Dec 6, 2017 | 08:57 PM
  #105
doveguy1's Avatar
doveguy1
Replacement struts
Originally Posted by Tunerz_Store
TEIN Dampers - Street Basis: TEIN Street Basis Damper is the evolution of the popular BASIC coilover model. It incorporates new internal and external components, newly developed coatings and new manufacturing processes.
TEIN engineers have spent many hours developing new seals and internal components to improve durability and product life. This was one of our major goals for the new model.
Newly developed “ZT” coating for improved durability and hassle-free ride height adjustment. TEIN developed this coating in-house after stringent test and analysis procedures. Our engineers tested different coats, application methods, cleaning processes, etc… in our own brine salt water testing machine which simulates heavy solvents/ road salts used in cold weather climates.
Slip-fit threaded adjustment tube. Allows for damper body and threaded sleeve to be thoroughly coated for rust/ corrosion protection.
The slip-fit allows a more thorough coating on the threaded section as well as powder coated damper body.
Revised Aluminum Spring Seat and Delrin Thrust Washer are light weight and durable. This combination allows for smooth ride height adjustment. The new spring seats have a larger contact surface area and eliminate the need for a rubber spring seat.
Specs:
Spring Rate (lb/in):F: 9kg/mm, 504lb/in R: 8kg/mm, 448lb/in
Upper Mounts: reuse stock
Adjustability: height only
EDFC Compatibility: no
FITMENT:
Infiniti G35 Sedan 2007-2008 (RWD)
Infiniti G37/Q60 Coupe 2008+ (RWD)
Infiniti G37/Q40 Sedan 2009+ (RWD)
Nissan 370Z 2009+
PM me for the best deals!!!
I am looking for an OEM spec front struts for an 08 Infiniti g37.
our coil overs a performance adjustable spring strut.
not real hip on lowering,
any suggestion?
Tom Dove 480 277 0191
