Vendor **Super Spring Sale! Best deals on springs PERIOD!**
Old Jul 1, 2013 | 11:09 AM
XTRPerformance's Avatar
XTRPerformance
Tein
H-Tech
Spring Rate (F): 325lbs/in (5.8kgf/mm)
Ride Height (F): -1.5in (-37mm)
Ride Height (R): -1.3in (-34mm)
Spring Rate (R): 263lbs/in (4.7kgf/mm)
TEIN Springs - HTech: High Tech is made from a new material called "Vanadium" which is much lighter then other spring and increases flexibility.
*Features*
* All spring are designed specifically to fit each car for maximum performance
* About a 1 inch drop for a more attractive appearance
* Comfortable ride quality is still maintained by using the OEM bump rubber and noise protection sheet (available for most model)
S-Tech
Ride Height (R): -0.9in (-23mm)
Spring Rate (F): 358lbs/in (6.4kgf/mm)
Ride Height (F): -1.2in (-30mm)
Spring Rate (R): 274lbs/in (4.9kgf/mm)
TEIN Springs - STech: TEIN S.TECH Spring is an excellent step towards suspension tuning.
They offer approximately a 1.5 inch drop for a more aggressive appearance. Comes with a 1 year limited warranty.
Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects.
*Features*
* One year limited warranty
* High-grade material adapted to improve guaranteed satisfaction
* Rubber spring protector sheet to prevent noise (most applications)
Eibach
Eibach Pro Kit
Front Lowering: 1.2in
Rear Lowering: 0.8in
Eibach Pro Kit Springs: The Eibach Pro-Kit is the perfect answer for most frequently-driven street cars. It´s our legendary spring system that dramatically improves both a vehicle´s performance and appearance.
Pro-Kit lowers your car´s center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach Pro-Kit is the finishing touch to a winning recipe for performance. Pro-Kit also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Every Eibach Pro-Kit is designed and tested by our suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, Pro-Kit provides the ultimate balance to take your passion for driving to a whole new level.
*Features*
* High Performance Handling and Aggressive Good Looks
* Lower Center of Gravity -- Lowers Vehicle 1.0" - 1.5" (lowering amount varies by application—use our application look-up for specific information on lowering for your car or truck)
* Stop Quicker, Corner Faster and get Better MPG
* Progressive Spring Design for Excellent Ride Quality
* Million Mile Warranty
H&R
H&R Sport Springs
Front Lowering: 1.3in
Rear Lowering: 1.2in
H&R Springs - Sport Springs: Every spring produced by H&R comes from the H&R ISO 9001 certified engineering and manufacturing facility in Germany. All H&R springs are produced from a special 54SiCr6 spring steel, which has strength rated at 290,000 psi resulting in unrivaled tensile strength and resiliency.
H&R Sport Springs offer the handling characteristics and aggressive appearance that you’ve been looking for, without the harsh ride characteristics of less-advanced spring systems. H&R Sport Springs feature more control and are engineered for the street, making them comfortable and fun to drive. H&R Sport Springs are crafted from a special 54SiCr6 spring steel to ensure quality and performance.
Old Jul 2, 2013 | 04:05 PM
XTRPerformance
All PM's replied. Thank you for your business everyone. Be sure to check out our other deals and ask us about package deal pricing!
Old Jul 3, 2013 | 05:02 PM
XTRPerformance
Old Jul 5, 2013 | 02:49 AM
XTRPerformance
Old Jul 5, 2013 | 05:05 PM
XTRPerformance
Old Jul 6, 2013 | 04:55 PM
XTRPerformance
Old Jul 7, 2013 | 04:41 PM
XTRPerformance
Old Jul 8, 2013 | 10:46 AM
XTRPerformance
Old Jul 10, 2013 | 06:59 AM
XTRPerformance
Old Jul 10, 2013 | 12:37 PM
XTRPerformance
Old Jul 11, 2013 | 08:29 AM
XTRPerformance
Old Jul 12, 2013 | 03:35 PM
XTRPerformance
Old Jul 13, 2013 | 04:06 PM
XTRPerformance
Old Jul 16, 2013 | 01:38 PM
XTRPerformance
Old Jul 17, 2013 | 11:30 AM
XTRPerformance
