Sponsor **Fortune Auto | ISC | BC Racing** Best price or they are FREE!**
For a limited time Fortune Auto, ISC, and BC Racing coilovers will be for sale from XTR Performance! We are doing some specials for the rest of this week.
Fortune Auto 500s
Retail $1199
PM us for the best price possible
All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification.
Features
Dyno tested
Stainless steel body / piston
30-way adjustable dampers
Pillowball mounts
Forged aluminum locking collars
Dust boots on all pistons
50mm piston-57mm piston housing (beyond the industry standard of 44-47mm)
Anodized aluminum camber plates** on front upper-mounts
Fully anodized body
1 year Manufacturer's Warranty
Height adjustment independent of preload
ISO 9002 certification
Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification.
Custom Spec Valving Options
Drag
Drift
Street
Track
ISC Coilovers
Retail $1250
PM us for the best price possible!
The N1 coilover can be lowered approximately 3 inches lower then standard ride height, this along with a spring rate setup to suit your car improves handling and stability dramatically. we make packages for track/rally/drag and of course street, to help our customers out even more we give them the option to pick there own custom spring rates at no extra charge.
32 Step Damper Adjustable
Precise control damp valve
Operates smoothly on all road surfaces
Expansion/Suppression of shock adjustment
Pillowball Uppermount
Adjustable camber allows more/less on road track for all conditions
Piston Rod Design
High rigidity steel piston rods
Meets with race/sport standards
Sports Spring
Made from high quality SAE9254 steel
Tested over 500,000 times on compression inspection with less than 5% deformation.
Choose from Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application, for specs check the application guide or ask us when you order, custom spring rates are free).
Ride Height Adjustable
Full length height adjustable
Bound adjustable with separate spring locks
High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminium Bracket
Made from T6061 aluminium alloy by organic shaping to lighten weight and increase handling performance
Specifically anodised surface to prevent inside corrosion and surface rust
On various models camber can also be adjusted via the bracket as well as the camber tops
Single Cylinder Design
Larger cylinder and piston design to advance driving stability and dexterity
BC Racing
Retail $1099
BC Racing BR Series Coilover Kit are the absolute best coilover for the money, hands down!
Features:
* 53mm Dampers (Larger then the Competition)
* Fixed Cup/Locking Collar Design (Unlike cheap coilovers, this feature will not change your ride heights, camber, or wear out your tires!)
* Full Pillowball Mounts in the Front & Rear. (where applicable)
* Rubber Inserts built in to keep the noise at a minimum.
* 30 Levels of Damping Force Adjustment(adjust compression/rebound)
* Separate Full Length Height Adjustable
* Clicks when you turn the damper handle allowing you can keep track of position
* One Year Warranty
* Rebuildable
Also, we offer optional rear extenders, which are a great accessory. They allow you to change the range of dampening without removing your rear seat every time.
BC Racing has the best warranty in the industry. They charge $95 per replacement coilover after the first year. There is no downtime as you will receive a BRAND NEW replacement coilover in lieu of sending it in for repairs!
Fortune Auto 500s
Retail $1199
Features
Dyno tested
Pillowball mounts
Fully anodized body
Drag
Drift
Street
Track
ISC Coilovers
Retail $1250
Piston Rod Design
Sports Spring
Aluminium Bracket
BC Racing
Retail $1099
Features:
* One Year Warranty
* Rebuildable
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
aktif8
05-23-2016 11:56 AM
