Whiteline Sway Bar Lateral Lock: OE and aftermarket sway bar effectiveness can be hindered by worn or inadequate mounts and links. Whiteline's new DIY Sway Bar Lateral Locks are designed to suit both OE & after market sway bars. The locks are easily installed on the car and mount directly next to the sway bar mounting point and prevent shifting or sideways movement of the sway bar under lateral (cornering loads). This results in improved sway bar effectiveness whilst preventing fouling of the sway bar on near by chassis and steering components.
For those who installed aftermarket sway bars, PLEASE PM us with the brand of Sway Bars you are currently running. So we can order the right size for you.
just curious, all aftermarket sway bars including OEM for the G37 already comes with lateral locks, some are welded into the bar, why would we need this?
You are absolutely spot on.... Yes they do, but most OEM sway bars including our don't come with lateral locks. Eibach has locks welded on the front not for the rear. Far as I know Hotchkis in only bars with both front and the rear locks welded.
are you sure? i have eibachs and they have them on both front and rear. I also found some images and tanabe sways also comes with them welded on
