Top ten reasons for Sway Bar UPGRADE!!!!!!
????Why do I need Eibach Sway Bars for MyG37????
TOP 10 questions my customers ask, when making a purchase of aftermarket sway bar.
1. My OEM already comes standard with Sway Bars. Why do I need to replace them?
2. I don’t track my G. Nor I drive my car fast. Do I still need to replace my Sways?
3. I have coilover system replaced on my G. Will sway bars still make noticeable difference?
4. I don’t have enough money now to spend on Sways. Can you give me some discount?
5. Can I replace my sways by myself? Or do I need to hire someone to do for me?
6. My G is leased, will I have problem when I return my car?
7. Do I have to replace end links for the sways?
8. Which company makes ideal sways for my G?
9. Will my aftermarket exhaust have problems with the new sway bars?
10. What is warranty on the sways?
Well above questions are what we face, before making most of our mods. By the end of this post you will find out exactly why you need new sways. Be able to make correct decisions what, when, and how to make sway bar upgrades.
1. My OEM already has sways……….
Well yes they do, however when engineers at Nissan (Infiniti) alike designed sways they did not have you the driver into consideration. When you are driving alone by yourself, no one else on the vehicle. You are pre-loading right side of your vehicle, which is direct affect from your weight on driver side. Does your G make left handed turns better than your right handed turns? Do you rub your driver side front wheels considerably more than your passenger side? Above two question if yes, is direct result of pre-load. Pre-Load is condition when you sit on driver seats and because of your weight affects opposite side of the cars sways. Well you could avoid right hand turns, or always carry your friends around. But 95% of the time you are driving alone.
2. I don’t track my G………….
Well even if you don’t track your G, with added balance of weight shift. Your tire will last longer. Performance gain of 50% - 60. Stable lane change at freeway speed.
3. I have coilovers, I don’t think I will need sways……
Well I track my G, and when I had KW V3 coilovers alone vs. coils+Eibach sways, I broke my lap time by more than 5 seconds. From stock coils vs. KW V3, 4 second gain. Price $$$$ on KW’s vs $$$ on Eibach.
4. I don’t have enough money to buy sways………
Well that is easy, to kick off our inception to MyG37.com forum. 35% off retail shipped (US & Canada) on sways from Eibach for G’s. Plus Eibach will give you a mail in cash for 10% now until 12/31/2010(US Customers Only).
5. Can I replace Sways by myself?
Yes only difficulty I encountered was to remove axle back exhaust just enough opening to insert new ones.
6. My G is leased…..
Make sure to keep your stock oem bushings and sways. And silicone lubricant that came with Eibach sways. Replace them before returning. And I am sure you will receive 100% back for your sways while you have used. Because you can resell them, at the price you purchased from us. Eibach gives you million miles warranty, so you could literally pass onto your great grand sons or daughters.
7. Do I have to replace endlinks too?
No with Eibach strongest and most aggressive sways on the current market. You don’t need to replace to adjustable end links. They are rigid enough to make pre-load weight obsolete.
8. Which company makes ideal sways?
Very easy Eibach does.
9. Will after market exhaust cause problem?
No because Eibach sways are mm’s thicker than your stocks. Not inches.
10. Warranty?
Eibach 1’000’000 miles warranty.
11. Our Exclusive unbeatable price @ http://www.aftermarketuning.com/eiba.../i-285991.aspx
10. Warranty?
My latest update from Tanner @ Eibach March 30, 2011 10:00am Pacific Standard Time
Eibach has produced so far
80 front sway bar for G37 excluding AWD
75 rear sway bars for G37 excluding AWD
45 received bushings from their supplier
0 silicone lubricants
So we are almost there. Just hang in there. I do apologize for all the delays.
John@ Jeb Performance
10. Warranty?
10. Warranty?
