Vendor SPL PRO Camber Parts and More!! $1 Shipping!!
Old Sep 10, 2010 | 05:01 PM
Mike@Czp's Avatar
Mike@Czp
We are selling these SPL PRO Parts at great prices. Take a look and take advantage of the prices while you can. Click on "Add to Cart" to be redirected to our site for more information and pricing.
BRAND NEW!!!!
SPL FUA Z34 Front Adjustable Upper Control Arms 07-08 G35 Coupe, 08+ G37 Coupe CV36, 09+ G37 Sedan V36, Free Shipping!!!
_________________________
SPL PRO Rear Toe Links - G35 07-08 Sedan, G37 08+
SPL PRO Rear Toe Bolts - G37
SPL PRO Rear Camber Links - G35 07-08 Sedan, G37 08+
SPL PRO Rear Traction Links - G35 07-08 Sedan, G37 08+
SPL PRO Eccentric Lockout Kit - G37
SPL PRO Rear Knuckle Monoball Bushing Set - G37
SPL PRO Adjustment Wrench - G37
If you have any questions, you know where to reach me. Thanks.
Mike
Old Sep 13, 2010 | 03:58 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Sep 13, 2010 | 06:07 PM
Hey Mike, if you could ask them to speed up the development for the G37 coupe sway bar end links I'll buy them the second they're available.
Old Sep 13, 2010 | 06:39 PM
AvosG37's Avatar
AvosG37
what r these? SPL PRO Eccentric Lockout Kit, SPL PRO Rear Knuckle Monoball Bushing. wat does this do?
Old Sep 13, 2010 | 06:41 PM
Mike@Czp's Avatar
Mike@Czp
Click on "Add to Cart" for pricing and descriptions:
Monoball: Our monoball bushings for the rear knuckle replace the stock mushy rubber bushings with low-friction articulating spherical bearings, eliminating bushing flex and reducing bind/friction. This maintains optimum suspension geometry under load, to improve handling and feedback, for high performance street cars, or for racing and drifting.
Our bushings feature bearings with an injection molded slot-loaded liner that cannot "pound out" when dirt gets on the bearing ball, providing a self cleaning and self lubricating bearing that is suitable for street use. Highly precise (machined to 1/1000th inch) CNC machined T6061 aluminum bearing shell for proper fit.
Eccentric Kit: The stock eccentric bolts provided by Nissan for small camber/toe adjustments tend to slip under high cornering loads (such as when racing or drifting), causing changes to the rear alignment. Our eccentric lockout kit eliminate the stock eccentric bolts to keep your rear alignment where you set it. You must have adjustable control arms in order to adjust camber and toe after eliminating the stock eccentric bolts. Our lockout plates are CNC machined from T6061 aluminum and supplied with grade 10.9 hardware to locate the pivot point precisely.
Old Sep 13, 2010 | 07:01 PM
VA_55's Avatar
VA_55
shipped to 91303
Old Sep 13, 2010 | 07:57 PM
g35sedan5at's Avatar
g35sedan5at
yes, if they can hurry on the endlinks and front camber kit id buy in an instant.
Old Sep 14, 2010 | 03:01 AM
Mike@Czp's Avatar
Mike@Czp
PM's Sent
Old Sep 15, 2010 | 03:44 PM
Mike@Czp's Avatar
Mike@Czp
bumped!!
Old Sep 17, 2010 | 03:19 PM
Mike@Czp's Avatar
Mike@Czp
bumped!!
Old Sep 20, 2010 | 04:44 PM
Mike@Czp's Avatar
Mike@Czp
bumped!!
Old Sep 21, 2010 | 05:00 PM
Mike@Czp's Avatar
Mike@Czp
PM's Answered
Old Sep 23, 2010 | 03:34 PM
Mike@Czp's Avatar
Mike@Czp
Bumped!!
Old Sep 24, 2010 | 03:47 PM
Mike@Czp's Avatar
Mike@Czp
PM's Answered
Old Sep 24, 2010 | 03:55 PM
Any info on G37 end links?
