Would you replace these? Should I?
Old Feb 16, 2024 | 06:39 PM
Scottfreidel's Avatar
Scottfreidel
Should these be replaced?
I have the calipers removed for brake pad and rotor replacement. After inspecting the calipers, I noticed a lot of wear and tear on the piston seals. Is it worth replacing them? They aren't cheap and it seems slightly difficult to replace them. Is it a concern to leave the bad ones in? Any step by step guides on replacing these? I've read that you use compressed air to remove the pistons.
Thanks.
Old Feb 21, 2024 | 09:27 PM
OrionRaphael's Avatar
OrionRaphael
Those first ones look pretty ragged. If they're cracked and no longer sealing, you definitely should replaced them right away. If you can wipe them off and the rubber is pliable and uncracked then they're alright is a good low resolution test.
Martinez1041
Feb 12, 2024 01:28 AM
Ace_07
Jan 9, 2021 03:04 PM
droxia
May 26, 2020 01:56 PM
jorwick
Picture Share G Sedan
40
Mar 28, 2012 03:06 PM
wakeboardr116
Jul 26, 2011 11:28 PM
