Is this replaceable?
Old Aug 23, 2022 | 10:20 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
I have used 50/50 acetone/ATF for longer than I care to remember and have always had good results. However, I would just use whatever you have on hand. If all you have readily available is "Liquid Wrench" then go with that
Me and fire do not mix well. Others more experienced may chime in on the benefits of using a torch.
When I joined the USAF in 95 the backyard mechanic go-to (and many pro mechanics) was acetone/ATF mix or PB-Blaster.
The USAF (and all FAA-rated passenger aircraft) only allows AeroKroil. Just due to shop availability, I've been using Kroil for 27 years now. Bought my last can in 2008 still have over half.
Old Aug 23, 2022 | 01:06 PM
Arthur Dent's Avatar
Arthur Dent
I thought I had some Kroil but couldn't find it. I can picture the burnt orange can...unless i am thinking of something else.
Old Aug 23, 2022 | 01:12 PM
rotarymike's Avatar
rotarymike
That's the stuff.
Amazon Amazon
Not cheap, but you'll have that one can last ages.
Old Sep 6, 2022 | 09:27 PM
Arthur Dent
I managed to get 6 of the 8 bolts removed. I ended up stripping one out with my impact and the other one was already rusted to the point that a socket would not even grab it. I am taking it up Thursday to a guy I know at a body shop. He thinks he can remove them pretty quickly. Curious to see what he does. For the ones I did manage to remove, I replaced with new ones as I got them out.
Old Sep 7, 2022 | 06:42 PM
beefychicken's Avatar
beefychicken
And the saga continues.... The guy at the body shop will probably use lots of heat and few swear words. In my experience, the heat accomplishes more than the swear words.
Old Jan 3, 2023 | 11:04 AM
mongo312's Avatar
mongo312
Arthur,
Was researching this same part rust problem and had concerns it was welded into a larger subframe. Glad to hear its just bolted on. Strange thing is the 2011 FSM only shows three bolts per side. Gonna have to crawl underneath and verify number before ordering. How did the job turn out? Really like the idea of holding the part in place with new bolts till all the old ones are removed.
Old Jan 3, 2023 | 11:54 AM
mongo312's Avatar
mongo312
Misread the FSM figure - it does show four bolts per side. Need stronger reading glasses.
Old Jan 10, 2023 | 03:06 PM
projectpanda13's Avatar
projectpanda13
Originally Posted by mongo312
Arthur,
If you haven't bought a replacement brace, I have a good condition one in Atlanta, but i can ship also.
I'm asking $200 + shipping
Old Jul 26, 2023 | 10:42 PM
Shivirac's Avatar
Shivirac
Do you still have the crossbrace? Need to replace mine too.
do you still have this crossbrace? Possible to get a pic?
Sena
Aug 21, 2012 01:45 PM
Calvin
Picture Share G Coupe
18
Sep 10, 2009 06:33 PM
gt_performah
G37 Convertible
24
Jun 11, 2009 12:05 AM
DaCePtak0n
Jun 4, 2009 09:07 AM
C@ciQ
93
Apr 1, 2008 02:24 PM
