Rear Brake Pads Wearing Unevenly
Old Mar 4, 2021 | 05:51 PM
ChefMatt's Avatar
ChefMatt
Did my rear brake pads 5 months ago - I installed CarQuest Gold ceramic pads. Was going to do my front pads as well, but they had and still do have plenty of meat on them. Did a tire rotation today, my mechanic showed me very uneven wear on rear pads - right side (passenger) was wearing out much faster than left (driver). Probably the caliper sticking, so I am going to replace both rear calipers, and add stainless steel rear lines. Has anybody experienced this? Any recommendations on calipers? Rockauto has plenty of weather-coated options....but big price diff. Thanks!
Old Mar 4, 2021 | 08:06 PM
stealthee's Avatar
stealthee
No need to replace the entire caliper. Its most likely just the pins. You need to clean them up and use brake grease on the slide points.
Old Mar 4, 2021 | 10:47 PM
Epiphany's Avatar
Epiphany
If you're doing all that, depending what you drive you may as well do a big brake upgrade if you don't have it already. Definitely worth giving everything a clean and lube to see if that fixes it before you throw a bunch of money at it.
Old Mar 5, 2021 | 07:07 AM
ChefMatt's Avatar
ChefMatt
Yes, I'll give the pins a look. I have a tendency to throw parts at an issue, especially if I can DIY it. I'll start small and give the brakes a lube and new pads, see if that works. I am also going to check the temps of my rotors this afternoon, although that would just confirm what we already saw with the wear. Thanks for the advice!
Old Mar 7, 2021 | 08:22 PM
SkysG37's Avatar
SkysG37
If you've got the base model floaters, yeah check the pins.
This will only help if the inside and outside pads are wearing unevenly.
I read it as your driver side versus passenger side pads are wearing at different rates.
This is entirely possible with "intelligent" traction control. Braking one corner or another. Do you see your slip light a lot when you're jamming around town? I know I do!
Old Mar 8, 2021 | 05:39 AM
ChefMatt's Avatar
ChefMatt
Um yeah. I do not baby this car - those HFC's and intake noises at 4-6k rpm still really gives me a thrill. I am used to seeing that slip light...Changing the pads this week and greasing the pins, see if that helps...I'll post pics of the worn pads..
Old Mar 8, 2021 | 08:55 AM
SonicVQ's Avatar
SonicVQ
Make sure to clean out the old (and sticky) grease on the pins and inside the caliper pin holes.
Then use a black moly grease to lightly grease the pins and pin holes. This grease has a VERY long life, doesn't dry out and turn sticky and resists water.
gatchek
The M - Spot
May 10, 2014 07:58 PM
Aryrm Cheng
Mar 31, 2013 09:16 PM
ruffz
Apr 12, 2012 12:38 AM
Goonz
Oct 3, 2011 10:57 PM
Q8_G37S_Red
Nov 6, 2008 09:03 PM
