Wineing noise coming from rearend or Tires?
Old Jan 14, 2021 | 07:02 PM
JME377's Avatar
JME377
Put shorter rear tires on my G37. Went from 26.7"(225/55/17) down to 25"(275/40/17). Would that much of a change cause a noise coming from the rear end or axles?
Old Jan 15, 2021 | 12:34 PM
Hugh Jorgens's Avatar
Hugh Jorgens
No. Its probably the tyres themselves
Think about it.
Your diff is spinning slightly faster per speed. Its not like your diff has never spun at that speed before with the old tyres.
Example with made up numbers...
If its spinning at 6000RPM at 70mph with your new tyres...
With your old tyres, it spun at 6000RPM at 75mph.
Either way...its not doing anything it hasn't done before.
If it whined at higher vehicle speeds with your old tyres....
It will whine at slightly lower vehicle speed with your new ones.
But if it didn't whine before...
Old Jan 15, 2021 | 02:30 PM
JME377's Avatar
JME377
Think about it.
What about the angle of the rear axle shafts?
Old Jan 15, 2021 | 03:04 PM
Hugh Jorgens
That doesn't change with tyre size...
the wheel center is in the same spot. Diameter of the wheel or tyre doesn't change that.
Like...if you measure from some static reference point on the car...everything stays the same. If you measure from hub center to fender arch...it wouldn't matter if you had monster truck wheels or rollerskate wheels or no wheels at all. If the suspension compression hasn't changed and the diff mounting location hasn't changed...the axle angle hasnt changed. The diff is mounted to the car. Not the ground.
Besides...why would axle angle make the diff whine? The axle is bolted to a flange shaft and its a CV joint.
Old Jan 15, 2021 | 03:31 PM
JME377's Avatar
JME377
Like...if you measure from some static reference point on the car...everything stays the same. If you measure from hub center to fender arch...it wouldn't matter if you had monster truck wheels or rollerskate wheels or no wheels at all. If the suspension compression hasn't changed and the diff mounting location hasn't changed...the axle angle hasn't changed. The diff is mounted to the car. Not the ground.
Thanx my man!! No matter the tire size the rear will sit the same and will center the tires. only ground clearance would be affected
Old Jan 16, 2021 | 09:26 AM
Hugh Jorgens
No problem. Good luck finding the issue
unknown2k1
May 15, 2023 10:39 PM
Milkmoney
General Tech Questions
May 26, 2018 11:22 PM
hottoddyg37
Sep 30, 2010 09:13 PM
adam
Apr 20, 2010 03:09 AM
