Reducing Unsprung Weight: G37 Benefits?
Old Oct 9, 2019 | 02:35 AM
adroitus's Avatar
adroitus
I've been thinking about trying to reduce the unsprung weight on my G37 Sedan. I have the stock 17" Journey wheels with General AS-05's on them now. I don't have much personal experience in doing this, but the benefits sound pretty great. But, as we all know, things don't always turn out the way we are told they will. I would be looking at getting the lightest 18" wheels I could afford, along with 14" Akebono brakes with 2-piece disks. I don't think I would make weight the primary concern in tire selection though.
Has anyone else tried cutting unsprung weight, and has it made a noticeable difference? What was good and bad about the results?
Old Oct 9, 2019 | 05:21 AM
Surfnazi's Avatar
Surfnazi
Rotational mass like tires wheels or rotors generally is 1lb rotating is equivalent to 10 lbs inside weight
Old Oct 9, 2019 | 09:49 AM
Baadnewsburr's Avatar
Baadnewsburr
I can't think of a single thing thats bad about reducing unsprung weight..you can definitely feel it in the steering and acceleration....if you go to a lighter wheel though you want to get a forged wheel as lighter cast wheels compromise strength
don't underestimate tire weight though.... from manufacturer to manufacturer theres a great deal of variance for the same size tire also within a particular manufacturer going up or down one size may make a significant weight difference...I have even found with a few tires going to a larger size tires are sometimes lighter for some reason.
you sound like you're on the right rack as it is, some other things to consider if its in budget titanium control/camber/toe arms if you are looking ot get adjustable suspension...if its jsut for weight thouhg the returns begin to diminish with these items
Old Oct 9, 2019 | 01:21 PM
BeeW's Avatar
BeeW
If you're really going for lightweight, theres always the like 80lbs of sound deadening foam and creature comforts you can rip out.
The easy stuff; Pull the spare tire, the hood liner, carpets, etc... That's gotta be like 50lbs at least.
Old Oct 9, 2019 | 02:42 PM
bPChaos's Avatar
bPChaos
I went from the stock OEM 19's to a wider, lightweight 18'. Total weight saved was about 15-20lbs per wheel/tire combo. Also threw on 2pc rotors on the front, so I cut about 60lbs? total of rotating, unsprung weight off the front axle alone. The difference was instantly noticeable. Steering felt way more precise, the car felt like it accelerated harder and it actually felt more comfortable.
You have to remember that when you remove weight of a rotating mass, you remove some of it's tendency to resist change in movement - think of a lightweight gyro vs. a heavy one, and ones at the very extreme corners of the car. For me, there were no downsides other than cost.
Old Oct 9, 2019 | 09:22 PM
sc10692's Avatar
sc10692
Pretty much this. Also noticed the car rolled much easier just letting the clutch out.
Old Oct 10, 2019 | 12:49 AM
bPChaos's Avatar
bPChaos
Oh, thought of another thing. You'll get better gas mileage too, if a bit marginal.
Old Oct 10, 2019 | 06:09 PM
Conboss's Avatar
Conboss
I currently have 17's(winter setup) and 18's(Summer setup). Basic brembo rotors. Looking to get my rotors replaced as they have warped, and wondering what people recommend. Also would like to get 19's for my summer setup and flip some new tires on the 18's.
(Might list the winter setup in the classifieds after this season, if I find the right wheel!
Old Oct 10, 2019 | 11:09 PM
SkysG37's Avatar
SkysG37
Keep in mind, when you drastically change unsrung weight, you may just have to "tune" the suspension. Rebound and damper rates specifically (think adjustable coilovers)
As the stock suspension is set up to handle the stock rim and tire.
You can actually hurt traction with too heavy of a spring and damper.
Old Oct 11, 2019 | 12:17 PM
slartibartfast's Avatar
slartibartfast
Originally Posted by Conboss
... Looking to get my rotors replaced as they have warped, and wondering what people recommend...!
Rotors rarely warp anymore. You probably have uneven pad deposits causing the pulsation. Do an "Italian Tune-up" (brake bedding procedure) before spending any money.
Old Oct 11, 2019 | 01:29 PM
Conboss's Avatar
Conboss
Oh trust me, not spending any money on this right now. Pads and rotors are under warranty, and I’m going to replace all the clips, sliders, grease everything and check out the caliper. If the caliper is starting to show issues, I’ll have to look at other options. BBK might be out of the question for me due to 17’s.
Old Oct 12, 2019 | 01:49 AM
slartibartfast
So, let us know how the Italian tune-up works, since it's free
Old Oct 12, 2019 | 08:18 AM
Before anyone calls the PC Police (of which I'm a citizen volunteer ), here's a little background on the phrase, which came from the race track in reference to a Ferrari technique from years ago.
http://en.wikipedia.org/wiki/Italian_tuneup
Old Oct 14, 2019 | 08:08 PM
ngolbuff's Avatar
ngolbuff
Great, now we will have people claiming they are doing daily "Italian Tuneups" because they redline their cars at every stop sign
Old Oct 15, 2019 | 09:00 AM
Conboss's Avatar
Conboss
Only when I have a couple km ahead of me and a tank of gas and a heavy foot, will I consider that an Italian tuneup. Quick redlines aren’t the same.
