Lower control arm
Old Feb 28, 2019 | 02:24 AM
Adam saf's Avatar
Adam saf
Lower control arm
I was wondering if someone can tell me what this part is. It connects from the lower control arm to the spring/shock. This is the front driver side btw.
Old Feb 28, 2019 | 10:42 AM
Said Amir's Avatar
Said Amir
It’s called the mount arm it’s part number 56132-jk50b
Old Feb 28, 2019 | 10:45 AM
Said Amir's Avatar
Said Amir
This
Old Feb 28, 2019 | 01:30 PM
Adam saf's Avatar
Adam saf
would this part cause noise coming from the front end or would it be the lower control arm? It’s like a squeaky noise when I turn the steering wheel and when I go over bumps. My mechanic told me this is the part I need but I find it hard to believe that this would cause those noises
Old Feb 28, 2019 | 03:10 PM
slartibartfast's Avatar
slartibartfast
Check your sway bar mounts and end links first. These commonly make noise.
Old Mar 2, 2019 | 01:18 AM
Said Amir's Avatar
Said Amir
Like he said ^ check the end links on your sway bars. Because I had mine making clunking noise when going slow speeds in really bumpy road and replaced them with Moog got it from rockauto, and you can grease them with a grease gun which will allow them to last much longer. And I do not have the clunking noise anymore. It also can’t be from the strut mount because the bushing for it is really tough to mess up and if this piece was messed up you would have a really bumpy ride up front of your car since it is connected to your strut. But check your endlinks that’s your main cause, if anything replace it and see since that is the cheapest option.
R1cky
May 21, 2016 10:11 AM
kame_sanjo
16
Oct 14, 2012 02:58 AM
NYG37S
Feb 8, 2012 07:26 AM
dudegetalife
Dec 16, 2011 04:34 PM
