Motorvate DIY Video: Reading TPMS Codes & Display Tire Pressures
Old Nov 17, 2018 | 01:17 PM
MotorvateDIY's Avatar
MotorvateDIY
Our latest episode shows you how to find out why the TPMS light is flashing -AND- how to see your actual tire pressures in real time.
Just by using a cheap OBD scanner, OBD Fusion and a $15 enhanced diagnostic add on:
Old Nov 17, 2018 | 02:27 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Great video as always!
@4:42, which value is what? 209kpa ~ 30psi, What are the other values in light blue (20.x, 29.x, 41.x kpa)?
Can this addon be used to register new tpms sensors? Anything equivalent in torque with the purchased nissan addon?
Does the addon let you toggle abs (during bleeding)?
Old Nov 18, 2018 | 11:30 AM
MotorvateDIY
Thanks!
Yes, 209 KPa is about 30 psi. I meant to add a graphic to that part and show the pressure in PSI, but only remembered after the video was posted.
(YouTube used to allow "annotations" where I could easily add them, but they are no longer offered)
The small light blue numbers are the minimum, average and maximum of that PIDs and it can not activate TPMS sensors.
Over the winter I will be looking into this to see if there is a way.
Torque Pro (as far as I know) doesn't have anything as comprehensive as the $15 OBD Fusion enhanced diagnostics.
The closest would be Infiniti EX plug in, but is only provides about 15-20 PIDs just from the ECU.
OBD Fusion (as far as I know) is read only, and can not activate anything, including the ABS module
Spoiler: On a future episode I will be cutting an G37 ABS module in half and explain its function. This will also help to determine if it really needs to activated to remove all air.
(Phew... so many good questions! time to re-charge with a coffee
Old Nov 18, 2018 | 03:18 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Thanks for the update.
Years ago I invested in the nissan addon to torque (in addition to torque pro). Looks obd fusion is a good update. $20 is cheap for all the data it provides. Now just a matter of learning how to interpret it all.
Old Nov 19, 2018 | 11:24 AM
MotorvateDIY
I think I can make the learning process a little easier for you...
You may want to have a look at my other YouTube channel: https://www.youtube.com/obd4everyone
The next episode (under development right now) will explain every engine PID (OBD mode $01) on the VQ37
WITH typical values. This will be very useful for troubleshooting
