Help wheel shaking at speeds above 60mph
Old Aug 24, 2018 | 02:54 PM
hockeyzbh's Avatar
hockeyzbh
Hmm ok ill let my mechanic know to check that out too. Appreciate it man
Old Aug 31, 2018 | 11:45 AM
hockeyzbh's Avatar
hockeyzbh
so brought the car to the mechanic and he couldn't find anything wrong. He said everything seemed tight. He said it could be a bent rim or something. one of my friends said maybe my spacer was bent but I don't think that would attribute to the shaking right?
Old Aug 31, 2018 | 04:45 PM
I'd check to be sure all your wheels have the hubcentric adapter rings, you mentioned the wheels have been on & off quite a bit. Possible that one of the rings fell out and was never replaced, or you didn't sound certain that you had them to begin with. Without the rings the chance of high speed vibration is very common, I would verify that you have them (and none are cracked or damaged) if they are be sure to get aluminum ones, much better than the plastic ones that come w/ some wheels.
Old Aug 31, 2018 | 04:47 PM
hockeyzbh's Avatar
hockeyzbh
Thats actually a good idea cause when i bought the newest rim i didnt even check to see if it came with that. Where would the rings be on the rim?
Old Aug 31, 2018 | 07:23 PM
here's a good clip on that
Emon Crew
30
Sep 22, 2016 03:27 PM
FlyIce
Oct 13, 2015 08:39 AM
rob145
Jul 20, 2014 01:18 PM
cruzmisl
Mar 11, 2012 04:21 PM
enforcer
Nov 24, 2010 01:10 PM
