Traction and Brake lights
Under HARD acceleration I will get first my Brake light then if I am on it long enough the Traction light will come on. The Brake light comes off but the Traction light stays on till I cycle the ignition. It is not the brake fluid and I have changed my pads already. I am running Coupe wheels with 275 35 and 245 40. Does the code get stored so I can pull it from the ECU with a standard scanner? I am thinking the speed sensor or maybe the ABS sensors may be going out. Not sure and want to nail this down. If I drive around "normally" nothing but when I get on it they flicker and maybe the Traction stays on.
Thoughts?
Thoughts?
I have this same issue. I am running anniversary 19" vert wheels (non-square). Same symptoms. I do need an alignment that I do know.
Brake fluid looks filled enough but I'll be doing brake upgrade soon so I didn't check it very well.
I'm having this same issue right now, same exact symptoms. It's been going on for a bit and now it doesn't even have to be hard acceleration, just anything over 3000rpm seems to be about the magic number. I know my rear brakes need to be replaced so I'm siding with clovissimo as to it being the issue.
Glad I could chime in 4 months after the last reply
