help please Gonna get these 19 oem powder coated
Old Apr 20, 2017 | 06:23 PM
Kpmikey808's Avatar
Kpmikey808
19 oem front 35 offset back 40
These should be fine on a 2k13 g37 sedan
What size tires should I run & wheres the best spot for a deal
Old Apr 20, 2017 | 08:38 PM
Check the other post in the sedan section, those offset aren't correct for OEM 19s.
If you want to run the same tire all around the 245/40/19s is the way to go, just be sure to keep the wider wheels in back.
Old Apr 20, 2017 | 11:41 PM
Kpmikey808's Avatar
Kpmikey808
Can it be staggered 35/40
Old Apr 21, 2017 | 12:10 AM
the93owner's Avatar
the93owner
Yes, I ran the same size tires on my staggered OEM 19" wheel setup.
Old May 2, 2017 | 10:19 PM
Kpmikey808's Avatar
Kpmikey808
Have u ever seen these from Niche?
ive done research & cant find these any where on there even for older niche rims cause they have been around for a long time
i appreciate the input & help mahalos
being picky about the rims & trying to bargain too lol
Old May 2, 2017 | 10:20 PM
Kpmikey808's Avatar
Kpmikey808
Hub caps
did they just buy hub caps from niche & just Change middle center cap?
Old May 3, 2017 | 10:13 PM
guy from norcal's Avatar
guy from norcal
Those are niche rhine's.
They are a discontinued.
