Suspension upgrades for 2013 G37X sedan
Old Mar 30, 2017 | 06:28 AM
Lego_Maniac's Avatar
Lego_Maniac
Originally Posted by goldhawg
If I went with IPL springs, does it matter a version/year to work with the AWD? Are the springs sufficient to add to my strut, or do I need IPL struts too?
The IPL is RWD, your car is AWD. IMO the springs are designed for different weights/distribution.
The front suspension on the RWD cars isn't compatible with the front suspension on the AWD cars.
RWD springs off a coupe or Z are a half-a** solution for a improving the handling on an AWD sedan.
Here's a better solution: https://www.myg37.com/forums/private...ngs-4n907.html
Old Mar 30, 2017 | 07:44 AM
Ape Factory's Avatar
Ape Factory
The IPL dampers (struts) won't work on an AWD as the bottom yolk on the AWD is different. So only the springs will work.
But as I stated earlier, you're going to see an improvement with wider, larger diameter wheels and better tires. The Bridgestone RE050A's found on the COUPE sports suspension are high performance tires with a very, very stiff sidewall. I know someone commented earlier about there being no difference between the base and S suspension on the sedan (other than wheel size) but we're comparing it to his wife's G37S coupe.
Old Mar 30, 2017 | 07:47 AM
Ape Factory
Except he didn't want to lower the vehicle. The weight balance isn't all that different and unless you know what the the OEM spring rates are for the X Sedan, there's no way of knowing if the IPL springs create an imbalance (highly unlikely). Higher spring rates WILl increase damper wear long term but assuming the free length is the same, the wear rate would be far less than Swift lowering springs.
EDIT: I just looked up the Swift spring rates and the X Coupe car must understeer like a barge given what they specify for that car, even worse than the 2wd cars based on the spring rates. On the X sedan, the ratio f/r makes more sense but the rate's still fairly soft. Just for reference, the IPL rates are 9.8K front and 8.05K rear.
http://www.swiftsprings.net/products...t-springs.html
Get a more aggressive tire/wheel package then upgrade to a matched sway bar set (assuming they make one for the X). If it's still not there for you, find some IPL springs.
Old Mar 30, 2017 | 08:42 AM
Lego_Maniac
Swift Springs USA
You can't have your cake and eat it too. He wants stiffer suspension but doesn't want to go coils or lower. Those objectives conflict.
Even if he is comparing a xS coupe, the only difference is still the wheels/tires, which is the easy thing to upgrade.
Old Mar 30, 2017 | 11:11 AM
Baadnewsburr's Avatar
Baadnewsburr
Just curious, but I reread this thread and I don't see anywhere that the OP mentions that his wifes care is an S model or a coupe. I only saw where he mentions that he has an x sedan and his wife has an XS (presumably a sedan).
If its a comparison between the sedan and the coupe even at the same trim there will obviously be further differences but I was curious because I didn't see anything in this thread.
Old Mar 30, 2017 | 12:38 PM
goldhawg's Avatar
goldhawg
Her car is a 2011 G37xS sedan (red) and mine is a 2013 G37X sedan (black). Ironically, when I bought mine last year, the dealer had an xS that I could have bought at the same price, but it was red too! I couldn't have two identical cars. But here in Ohio, I love the AWD, and because of the snow in winter, I'd rather not be much if any lower. If the sway bars are as good as they say (have a line on a set in the classified for new Hotchkis AWD bars), maybe that's enough. But if not, I was wondering the next steps. As for those that think I'm not able to tell the difference in ride, they're wrong. Come to the Dayton area and I'll show you! I've had others drive and the difference is noticeable, especially above 80 mph (ahem...not that I ever go above 80!).:-)
Old Mar 30, 2017 | 12:55 PM
Selym's Avatar
Selym
Now that we're clear that both cars are AWD sedans, I'll reiterate that there's no difference in the suspension between the two. The only difference is the wheel and tire package.
Isn't there a dealer selling the "duckfeet" wheels for dirt cheap?
Old Mar 30, 2017 | 01:10 PM
Lego_Maniac
What size/type tire on each car?
Old Mar 30, 2017 | 02:14 PM
goldhawg's Avatar
goldhawg
I'm not buying there is no difference. The rear sway bar size alone is significantly different. Supposedly the steering is different too. I have no idea about the springs/struts--you may be right.
But I don't doubt wheels could help. I'll buy some dirt cheap duckfeet wheels!
Old Mar 30, 2017 | 02:57 PM
Baadnewsburr
Again just curious but are you sure about this. i.e. have you seen the rear sway bar on an XS? I think those mentioning the bigger swaybar were referring to it being from the S model, which is indeed correct.
Edit: jsut looked it up. the part number for the 2011 XS Sedan rear sway bar is the same as the part number for the rear sway bar on the 2013 x sedan (56230-JK000).
Old Mar 30, 2017 | 03:14 PM
Baadnewsburr
Anyways, as a far as a more productive suggestion goes. The 18" wheels (could consider ones off a 350z/370z in addtion to the G37xs/g37S (sedan or coupe) for a factory look), and some stickier rubber with stiffer sidewalls to get you to something closer to your wife's car.
the Hotchkis sways as a set or the OEM rear sway bar off a g37S or a 370Z would definitely help as well and are fully compatible (only the front is differently shaped)
If you don't want to go too low, the Swift springs for the AWD sedan (part NO. #4N907) are decent too but with the AWD the ground clearance is already only about 3 inches and a bit because of the transfer case hanging down so you should decide if they are fro you. I have them fitted and just plough through the snow with them. The bigger issue i have is not scraping my Y pipe at the crest of a steep incline or my bumper on a decline
Old Mar 30, 2017 | 03:20 PM
Lego_Maniac
Absolutely incorrect.
Only the RWD S gets the fast ratio steering.
Old Mar 30, 2017 | 04:32 PM
Selym's Avatar
Selym
Well, look up the part numbers yourself, then.
https://discountinfinitiparts.com
The rear stabilizer bar (a.k.a. "sway" bar) for both X and XS sedans: Part #: 56230JK000
Old Mar 30, 2017 | 05:08 PM
  #29
Baadnewsburr
I'm pretty sure the part numbers for the steering rack are the same for the AWD S and regaular AWD as well and differ from the S as well...I remember seeing one or two threads where someone lookked into seeing if they could swap them a long time ago and there was a comparison of part numbers too
Old Mar 30, 2017 | 05:51 PM
  #30
Selym's Avatar
Selym
Apparently the steering racks differ between the AWD Sedan w/sport and AWD Sedan w/out sport:
Gear assy SEDAN, 4WD, w/o Sport tuned Part #: 49001JK65A
Gear assy SEDAN, 4WD, w/Sport tuned Part #: 49001JK65B
