Will lowering+spacers affect my winter setup?
Old Jan 12, 2017 | 01:45 PM
Obsi's Avatar
Obsi
Hi I have a 2010 G37S Coupe RWD with everything stock and I'm planning on getting Eibach lowering springs with the H&R DRM Spacers.
I currently have another set of winter rims 225/50/18 all around (Sport Edition A7 Black Painted) that have 35mm offset and 5.91" back spacing.
I've searched the forums and found I shouldn't have an issue with my stock rims if I go 245/40/19 and 275/35/19 tires with 20mm front / 15mm rear spacers but I'm not sure if my winter rims will clear the fenders or any issues with the fitment after I do lower it with the spacers.
Thanks.
Old Jan 12, 2017 | 09:23 PM
Thanks.
What width are the winter set? Should be fine as long as they currently clear your big Sport brakes.
Old Jan 25, 2017 | 10:02 PM
Obsi's Avatar
Obsi
My winter sets are 18" x 8"
Will my front wheels protrude out with the eibach springs and 20mm spacers?
I would like to go with F 20mm and R 15mm spacers with my stock 19's but I'm not sure with my winter set's 35mm offset and 20mm spacer. Any chance of rubbing..?
Thanks,
Old Jan 25, 2017 | 10:24 PM
the93owner's Avatar
the93owner
Thanks,
So your final specs will be 18x8 +15 with the 20mm spacer. I am running 9.5 +35 up front, and according to the tire/rim calculator, those two specs are almost exactly the same. With a drop and natural camber, you should be fine. I don't rub at all and it is nearly flush.
Old Jan 25, 2017 | 10:40 PM
Obsi's Avatar
Obsi
That's good news. I was concerned because I'm at stock height right now and without the spacer it already looks close to the fender. I guess the drop really tucks the wheels in!
