Bad Vibration and Dents in the rubber inner side wall!!
Did you ever find your offsets? This will determine how wide you can go, especially out back. Those wheel widths can accommodate a wide variety of tire widths. The following most common combos will work depending on offsets~
245/35/20front & 275or 285/30/20rear. If your current 255 rear tires are close to the fender edge you might have to still go with that size. If that's the case you could run a 225/40 front and 255/35 rear so both tires would be a stretch mount but would have close diameters.
Hopefully you can get those offsets posted before you order tires, don't want you to be disappointed again.
Might have some other tires to consider once you get the offsets up.
Brad
Brad
Tire Offsets
Okay Brad
This is what I found on the inside of the wheels
Front: laser inscription - 12.05.05 c04 2090 +20 5x114.3 SN CB 73.1
On the inside of the spokes:
MAX OVERALL 814 MM.
9.0J x 20H2
VVS-CV4
SAE J2530
ETRTO
Rear: laser inscription - 13.02.26 c04 2005 +25 5x114.3 SN CB 73.1
ETRTO
SAE J2530
VVS-CV4
815KG
10.5J x 20H2
this is all I can find on the inside of the front and rear rims. Hopefully my friend you can find the answers that are needed for me to buy the right tires,
thanks for all your help Brad.
Nick
MAX OVERALL 814 MM.
9.0J x 20H2
VVS-CV4
SAE J2530
ETRTO
ETRTO
SAE J2530
VVS-CV4
815KG
10.5J x 20H2
Nick
Yep, that would be what you have^^^ There's a couple tire combos you can go with~A 235/35/20 or 245/35front & 265/30/20rear would be an easier fit, especially in back. A 245/35/20 & 275/30/20 will be tight back there so you may have to trim your rear fender bracket. Depends if you are lowered, and if you want to run a bit more negative camber. At stock height I wouldn't run wider than the 265s.
Thanks guys.... I'm lowered on Eibachs only. And I'd rather not have to get into trimming wheel areas and running negative camber. It sounds like the easy way out but I'd rather just put the tires on the rims, have them balanced and put them on the car. And of course have no problems with them afterwards. So which is the best size for me and any ideas about good tires that are reasonably priced?
I've always liked the Yokohama S.Drives and the Hankook Ventus v12 evo12.
Hey Brad,
Is there an instructional video or a step by step how to do it with regards to trimming the fender bracket? I have heard of it before but have no idea how to do it. I'd really like to know how to do it so I have more options when I grab new tires.
Thanks
Nick
Thanks
Nick
Hey Brad,
Thanks
Nick
Thanks
Nick
https://www.myg37.com/forums/wheels-...r-bracket.html Might give a closer look at Ryne's setup w/ 255s all around, might make your life a bit easier (maybe), lol.
Mar 25, 2016 02:58 PM
