GodSpeed Sway Bars
Old Jul 19, 2016 | 04:42 PM
atdrennen's Avatar
atdrennen
GodSpeed Sway Bars
I'm a cheapskate and decided to give the the Godspeed sway bars a try.
2012 G37 sedan (non-S) daily driver, no other mods. Ebay seller, $118 shipped.
Bars arrived with a couple of scratches and chipped paint. I had read this from other reviewers, same for me. The bars are significantly heavier than stock. I can give OD mm comparisons if anyone requests.
Install was pretty straight forward. Everything fit. Came with brackets and bushings (rubber). I was able to get the rear bar out without loosening the exhaust etc. All I did was remove the brackets and end nuts on the bars, and was able to snake the thing out by bringing it towards the rear of the car and getting a little creative with the jigsaw puzzle. Was able to get the new one in the same way, albeit with a little more struggle.
I've owned the car for about 3 months completely stock. I just installed the bars yesterday and have only been able to drive them a little bit so far, less than 30 miles.
Initial impression are that I'm very pleased. Turn in seems much more responsive. Overall body roll is reduced. Transitions through switchbacks are much tighter.
I have no other experience with any other sway bars for comparison.
For the money - couldn't be happier. Hope this is helpful to someone.
Old Jul 19, 2016 | 04:53 PM
Glad to hear that your initial impressions are positive. Any issues installing the front bar?
Post an addition to one or both of these threads if you want and update as time goes on if anything changes for the better or worse.
https://www.myg37.com/forums/brakes-...g37-sedan.html
Old Jul 19, 2016 | 06:23 PM
atdrennen's Avatar
atdrennen
No issues with front fitment. The right rear bracket was a little snug, but seemed to tighten up just fine. Thanks for pointing out those other threads. I'll add to them when the bars have more miles.
Old Jul 19, 2016 | 08:55 PM
PNW_IPL's Avatar
PNW_IPL
What is the measurement of the new bars
Old Jul 20, 2016 | 12:16 AM
slartibartfast's Avatar
slartibartfast
I, too, ask for bar dimensions. I've got a bit of a database going. Can you tell if there is a seam on the bar ends that indicates a crushed tube instead of solid steel? And, were the bars the same shape as stock?
Old Jul 20, 2016 | 02:37 PM
atdrennen's Avatar
atdrennen
I'll follow up this evening with measurements and check the bar ends. The shapes were the same, based on a casual comparison.
Edit: 30.5mm OD on the front, 25.5mm on the rear. I couldn't get a good look at the bar ends - I'll roll it back up on the ramps and confirm in the next couple days.
Old Jul 22, 2016 | 06:26 PM
Kris9884's Avatar
Kris9884
Interesting! I have these saved to my wish list and was hoping someone would be guinea pig.. I'm completely oblivious to sway bars, is it normal to be heavier if they are more stiff or is that a "cheap" factor? Here's a link to them if it helps answer any questions..
http://www.ebay.com/itm/Godspeed-Fro...lRAZdc&vxp=mtr
Old Jul 22, 2016 | 06:51 PM
Godspeed Front Rear Sway Bar Swaybar Stabilizer for G35 G37 370Z 30 3 25 36mm | eBay
Those other two links I posted above are two other guys running them.
Old Jul 22, 2016 | 09:32 PM
slartibartfast
...I'm completely oblivious to sway bars, is it normal to be heavier if they are more stiff or is that a "cheap" factor?
For a solid bar, yes. For a hollow bar, it depends.
Old Jul 22, 2016 | 09:33 PM
PNW_IPL's Avatar
PNW_IPL
Anyone know the size of the front ipl oem?
I believe my ipl rear is over 26mm so no benefit there.
RochesterG37x
Picture Share G Sedan
Oct 24, 2019 05:12 PM
rsingerG37
Aug 15, 2019 01:05 PM
Robertomtz
Mar 31, 2016 10:29 AM
armino41
Mar 30, 2016 01:25 PM
