Tire Size - Square Set up
Old Jul 2, 2016 | 05:11 PM
VelisG37s's Avatar
VelisG37s
Forum,
I've currently got a 10.5" square set up on my RWD with 255/35/20 all around.
The rears are almost bald and I'm planning to replace them with either of the following sizes:
- 255/35/20
or
- 275/30/20.
Question is should I be staggered since the car is RWD? Or get the same size for all corners?
Thanks in advance
V
Old Jul 2, 2016 | 05:37 PM
slartibartfast's Avatar
slartibartfast
There is a handling benefit for staggered but you'll not suffer much in that regard staying square.
Old Jul 2, 2016 | 09:16 PM
VelisG37s's Avatar
VelisG37s
Will it alter in the speedometer reading?
VelisG37s's Avatar
VelisG37s
More input will be appreciated people
Old Jul 2, 2016 | 10:45 PM
slartibartfast
Use the tire calculator on this site to find that answer. Or, some simple math in a spreadsheet...
Old Jul 2, 2016 | 11:13 PM
Mkhlmnn's Avatar
Mkhlmnn
you'll get more understeer switch to a staggered setup and wont be able to rotate your tires so if your like me you'll have replace two sets of rears for every front (potenza s04s are amazing but dont last long im switching to 245/40-19 and 255/40-19 so it has less understeer but since I have as grippy tires idk if I want the exta oversteer from the staggered, handling will be more neutral the less stagger there is.
Old Jul 2, 2016 | 11:14 PM
Mkhlmnn's Avatar
Mkhlmnn
This is the best for comparing multiple sizes Tire Size Calculator - Tire & Wheel Plus Sizing
and this is comparing visual size and percentage change so you can keep your vdc happy.
https://tiresize.com/calculator/
Old Jul 2, 2016 | 11:20 PM
I'd stick w/ square, and run a small spacer if you want more flush in the back, like mentioned, being able to do a true 4 wheel rotation is a good plan.
BTW are your tires wearing evenly?
Old Jul 2, 2016 | 11:45 PM
slartibartfast
Running staggered allows a bit stiffer rear stabilizer. Or, it helps tame too much oversteer.
Old Jul 5, 2016 | 07:55 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
255/275 combo fine as well as 255/255. The wider tire out back will help plant the rear end in corners better, the 255s all around better wet traction with the narrower footprint. You'll lose the ability to rotate them if stagg as well. Majority of people run 255/275 for handling and looks. If that's not your goal, and you like the way its set up now, keep it square.
Old Jul 9, 2016 | 01:41 PM
VelisG37s's Avatar
VelisG37s
Went with 255 35 front 275 30 rear. Thanks for all the input!
zubi82
Apr 20, 2016 09:46 PM
gman69
Apr 18, 2016 10:11 AM
JohnsG37x
Apr 15, 2016 03:45 PM
7Head
Apr 10, 2016 08:22 PM
andrew4395`
Apr 6, 2016 09:08 PM
