Help Help me with camber kits
So i'm thinking of going with lowering springs for my 37 sedan, 09. I really dont want to spend the money on camber kits which seem pretty expensive, hence i decided to go with Tanabe NF210, which give you a drop that does not need a camber kit, according to info i've seen on here and g35driver. But, I would rather go with TEIN s-tech or eibach pro kit which give you the most drop as well as h&r, (correct me if im wrong) if i could find a cheap solution for camber kits. please help me out with sources or a less expensive solution.
thank you!
thank you!
so Tanabe's would be a pretty good way to go with a mild drop without having to worry about camber adjustment!? most people seem to not need the camber kits with these springs.
dragion
Feb 23, 2016 10:05 PM
