Floor Jack for brake jobs
)As far as being safe to work under a car w/ 4 jack stands, if they're on a flat surface (not an angled driveway for example) and you're not trying to bust locked-up bolts there shouldn't be a problem, but like Flakman stated, it's not really recommended (but being under a car w/ jackstand supporting one end and a jack supporting the other isn't recommended either. What I do whenever I'm under a car with just jackstands I have a couple old truck tires that just slide under the sides of the car rails, if god forbid, the car was to come off the stands there would be another source taking the weight.
I think if you already have a Costco membership I'd get the Costco jack since Lego Maniac mentioned above that their return policy essentially makes it a lifetime guarantee. That would be my suggestion, that said, the Harbor Freight jack has been a good one for me (but we don't have a Costco in town
I always wondered about the quality of the Harbor Freight jacks. But for $99 I can't see not buying the Costco jack. I know you're lowered, did you get the HF jack with a longer reach to get under your G? What's the minimum pad height (3.5" or 4")?
Jack stands are meant to be safe with one other axle on the ground and chocked. They are not meant to be used to hold the entire car off the ground to be worked on. Can they hold the weight? Yes. But they are not designed to be the sole support against lateral forces that occur when wrenching on a car (wheels, engine, etc). They are designed to be sturdy when one of the axles are on the ground while the tires of that axle are preventing any rocking of the vehicle. Read the instructions witb your stands.
I'll jack up the front under the engine cradle, place the front jack stands. Then jack in the rear under the diff and place the rear stands. The floor jack will be left nearest the end of the car i'm working on as a safety/backup. All this is done in a garage on a level concrete floor.
IIRC, the stands I use are rated at 3 or 4 tons per pair. Plenty to support a 2 ton car.
Edit:
I have 1 set of these : http://www.sears.com/craftsman-profe...ype=SKIP_LEVEL
and 1 set of the 3 ton version.
I've had my car with all 4 corners on jackstands a number of times; installing exhaust, tire rotation, bleeding brakes, trans fluid change, etc.
Edit:
I have 1 set of these : Sears.com
Edit:
Got the Harbor Freight aluminum 3 ton jack . Looks like good quality, however it barely fits under the front of the car (Coupe with sport pkg).
2 ton Low Profile/Long Reach Steel Heavy Duty Floor Jack with Rapid Pump
I bought this one a month ago for camber kits etc. I'm lowered on eibach and this "low pro, long reach" was a must. Although for the front jacking point I still need to roll up on two 1" boards.
Death of Bimmer Lover
Like Flakman has repeated over and over again in this thread, it is imperative that all precautions and instructions are followed strictly when using floor jacks, jackstands, etc. I remember reading this sad story when it was first posted on the bimmer forums, and I will never forget it. If you don't have time to read all the parts, skip right to part III written by the victim's father. Be careful and be safe, guys.
Harbor Freight Jack
Are you referring to the Pittsburg Automotive "3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump"? It's shown on the Harbor Freight website as being 29" long. That's long enough to reach the front and rear jack points?
Costco discontinues (maybe temporarily their 2.5 ton jack).
I'm very happy with the jack from HF.
PS- I did not physically checked , but I think the 2.5 ton racing jack is not long enough to fit and reach the front jack point.
