Help Tein Spring kit and 285/35R/19
Old Mar 19, 2015 | 01:10 PM
kratikosG37's Avatar
kratikosG37
I have 245/35R/19 on the front, but I want the same tire brand in the rear.
Will 285/35R/19 fit?
wheel size. 19x9.5 and 19x10.5
thanks
Old Mar 19, 2015 | 02:09 PM
thanks
Need to know the wheel offset and are you on a coupe or sedan, dropped or stock suspension?
Old Mar 24, 2015 | 12:55 PM
kratikosG37
+35 ish offset
Coupe
Tien dropped spring kit with factory coilovers.
Purchasing Micky Thompson Street Comp ET.
Old Mar 24, 2015 | 01:20 PM
+35 ish offset
Coupe
That's going to be close, but w/ a +35 offset you should tuck right into the fender, might have to dremel-trim the bumper bracket but should be OK.
Old May 28, 2015 | 01:59 PM
kratikosG37
245/35R/19 will be a certain fit, but I want the beefy tire look in the rear.
Want to have 0 camber in the rear, don't know if that's possible.
Does anyone have the same spring kit as I do with 285's in the rear?
Old May 28, 2015 | 02:30 PM
HoldmyMouse's Avatar
HoldmyMouse
FYI the diameter diff is >4%. I'm not sure if you will run into any problems with that staggered setup.
Old May 29, 2015 | 12:30 PM
kratikosG37
275 would work, but they don't make a 35/19R in that size.
side pic
gammamotors
44
Dec 31, 2015 12:48 AM
jfisher
Sep 13, 2015 07:58 AM
pal51961
Sep 6, 2015 05:34 AM
EnYcee-G
Sep 3, 2015 04:35 PM
dlc1988
Sep 2, 2015 09:40 AM
