BBK heavier or lighter than the non sport brakes?
Old Nov 15, 2014 | 05:26 PM
Razorr's Avatar
Razorr
So I have an AWD sedan and I upgraded to the sport Akbono brakes with stoptech rotors. The car was already heavy as it was. Do you think the bigger brakes put more weight? Now a lot of you might think it's a stupid question as bigger brakes mean more weight, but that's not true, I have seen performance BBK's that weigh less than smaller brakes.
Old Nov 15, 2014 | 06:29 PM
With the iron rotors the BBK is definitely heavier, much bigger (and thicker) mass of metal. BBK fronts are 355mm/32mm 30.5 lbs, rears 350mm/18mm 20.9lbs compared to 22.5/12.8lbs for the 320mm/28mm front 307mm/16mm rear base brakes.
Old Nov 15, 2014 | 07:19 PM
Razorr's Avatar
Razorr
Thanks, and that's quite a bit of weight added to an already heavy car
Old Nov 15, 2014 | 08:28 PM
At least my Wilwood calipers weigh 5.2 lbs
I think the OEM base floaters weigh about 15
Old Dec 19, 2015 | 11:50 AM
3POINT8's Avatar
3POINT8
So you guys think its better to upgrading to OEM BBK / AKEBONO from Infiniti is better than upgrading OEM base / non sport brakes ? In terms of braking performance and weight ?
I have a 2010 G convertible and sticking with 18s.
Deciding between these two packages
https://www.z1motorsports.com/brakes...ar-p-4296.html
or
https://www.z1motorsports.com/brakes...ge-p-4671.html
Old Dec 19, 2015 | 01:08 PM
Razorr's Avatar
Razorr
If you have 18s from the factory you might already have the OEM BBK. Btw the two packages you linked are miles apart in pricing. Ofcourse, you're better off with the BBK's for the most part, but it also depends on your needs. The BBK will help you more with brake fade rather than stopping power. The stopping power for both the setups are pretty close however, the BBK can dissipate heat better than the non sport brakes due to larger rotors, so if you track the car it will help you more. However, for day to day driving other than the looks you won't feel that much of a difference.
Old Dec 19, 2015 | 01:47 PM
3POINT8's Avatar
3POINT8
I was told the OEM BBK was only specific with "SPORT" / "S" models ? I have a base convertible and the brake calipers don't have the "Infiniti" logo stamped on it. Yes I don't plan on tracking the car, just want a little more braking power and cutting some weight if applicable.
I guess my question really is, which set up is lighter ? non sport oem brake kit or BBK akebono kit ?
Old Dec 19, 2015 | 02:45 PM
Razorr's Avatar
Razorr
okay then you don't have the sport brakes. But to answer your question, as blnewt mentioned the non sport is lighter than the sport akebono brakes.
Old Dec 19, 2015 | 02:55 PM
3POINT8's Avatar
3POINT8
OMG idk how I overlooked that ! Thanks for pointing that out. Guess i'll just stick with the nonsport brakes, just gonna upgrade the rotors/pads. Maybe powdercoat the calipers "speed yellow" for more a polish look
drive6MT
Sep 14, 2015 12:36 PM
joeposter
Sep 8, 2015 04:36 PM
Ihtbealexxx
Aug 9, 2015 03:30 AM
