DISTANCE FROM wheel hub mounting surface to fender lip surface
Old May 11, 2014 | 03:06 AM
enzo0706's Avatar
enzo0706
Thumbs up DISTANCE FROM wheel hub mounting surface to fender lip surface
Hello , everybody ,
have any of you measure the distance from wheel hub mounting surface to the fender lip surface ?
you know , i want to calculate the spec of the rim to set the best spec to fit it flush
cos i want to give our customer Hellafluch style ,infiniti .
Old May 11, 2014 | 11:04 AM
Originally Posted by enzo0706
Hello , everybody ,
Watch this little clip, should give you a good idea of how much spacing or offset you'll need to get the look you want. So if you need 15mm of spacing you'd just subtract 15mm of positve offset, so a +45 offset rim w/ 15 mm of spacing to get it flush would result in a +30 offset for example.
Old May 13, 2014 | 09:27 AM
enzo0706's Avatar
enzo0706
Thumbs up
How to Measure for Spacers - YouTube
thanks, i know how to measure the backspace , i means
the hellaflush is to make the lip of the rim should be flush with the fender , if we meansure the distance between the surface of the hub mounting and the fender surface . we can ues this date to choose rim to flush ? how do you think of this ?
i do not know how you guys and shop to help people get their car hellaflush ?
this is what i think in mainland China .
sorry so many question . thanks at all
Old Jul 6, 2014 | 10:52 PM
enzo0706's Avatar
enzo0706
i mean this distance , thanks .
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
james6980
Oct 9, 2015 01:28 PM
m3clubracer
Aug 26, 2015 07:36 AM
BOXER83
Aug 24, 2015 10:42 AM
