Help Wheel spacer question -19 inch stance sc-5
Old Jan 19, 2014 | 02:10 AM
shawnberry45's Avatar
shawnberry45
G37 coupe on stance coilovers with 19inch stance sc-5 rims(245 front, 275 rear)
Rears fit great front needs spacers to clear brakes and came with 3mm or 5mm non stud kind.
Do you recommend jus using these or better to go with 15mm all around? Never used wheel spacers so no idea
Thanks!
Old Jan 19, 2014 | 02:14 AM
LegitMW's Avatar
LegitMW
If the 15 makes it sit flush then go with the 15. If it is already flush with the 3 then go with the 3.
Old Jan 19, 2014 | 03:21 AM
shawnberry45
well thats kinda what im asking like is it safe to run 3mm or 5mm spacers without the studs? or better to get 15mm h&r kind instead all around?
Old Jan 19, 2014 | 11:00 AM
If 3mm will allow a 2mm clearance for your brakes, then you can run them w/ OEM studs (assuming your new wheels allow enough thread). If 15mm is too much a 10mm spacer is an option.
Old Jan 19, 2014 | 11:54 AM
shawnberry45
is running 5mm (sleeve non hr kind) ok as well?
Old Jan 19, 2014 | 06:58 PM
Might have to use extended studs.
Intake
Dec 25, 2015 09:38 PM
news1213
Dec 16, 2015 11:06 AM
ladydriveng37
Oct 11, 2015 05:23 AM
james6980
Oct 9, 2015 01:28 PM
GARRYDG07
Aug 11, 2015 08:32 PM
