Whirring noise/Roaring noise. Can it be wheel bearing already?
Old Jul 9, 2013 | 03:59 PM
unknown2k1's Avatar
unknown2k1
Good afternoon.
On my G37xS sedan, I noticed a noise coming from front of my car. It's been there for quite sometime actually.
The noise is typical such as described above in my title. So after tire rotation, I got alignment, tire balance and etc. but the noise is still there without any improvement. So I took it to a dealership to see if this would be something coming from Wheel bearing and hopefully get it covered by warranty - but of course they first recommend changing tires, which I can't disagree because it COULD be the tires. But the dealer was saying that tires are cupped. But I see no sign of cupped when I took a look; none the less, I don't think it's a bad thing to change tires since these are originals but my question to you guys is that --
Isn't cupped tires basically due to lose wheel bearing or in this case wheel bearing assembly?
I would hate to change tires and dealer then says they will look into somewhere else. Could this possibly be rotors? because sometimes my transmission shakes little when I brake and I'm guessing that's my warped rotors (brakes were changed not too long ago)
Dose anyone had this experience/issue or have any quick advise I can try before changing the whole tires? I guess what I'm trying to say is that I wanna know my wheel bearing are good so when my Warranty expires, I am okay!
Thanks!
Old Jul 9, 2013 | 04:22 PM
BLamb's Avatar
BLamb
I'm not positive this is the same process for AWD, but for RWD:
lift the wheel in question off the ground with a jack. Grab the tire at 12 and 6, see if you get any play.
Old Jul 9, 2013 | 05:45 PM
sniper27's Avatar
sniper27
Generally, cupping is caused by bad shocks.
Old Jul 9, 2013 | 10:18 PM
monty2003's Avatar
monty2003
I had this same issue on my 2003 G35. Sounded like bad bearings but when measured with a dial indicator all were in spec. Replaced the tires (they were "economy" performance all season tires) and the noise went away. I put another 50,000 miles on the next set (better quality) of tires with no noise.
By the time bearings start growling, they have play. BLamb's suggestion is good but you have to know what to look for because steer slop and natural give of the steering mechanism can act like bearing play.
I had an Integra once that made a growing/humming noise and was able to find plenty of slop with the tire wiggle test. Replaced the bearing and the noise was gone.
How many miles do you have on the car?
Could be suspension causing the potential cupping but unless you have a bunch of miles or a lot of hard miles, it's likely just the tires......
Brian
Old Jul 9, 2013 | 11:53 PM
financeman's Avatar
financeman
Tires can be very noisy....without always showing strange wear patterns. My bet is on the tires.
Old Jul 11, 2013 | 12:57 PM
unknown2k1's Avatar
unknown2k1
Little less than 50k so I doubt bearing for now, leading more towards to tires as well but now the issue is which tires LOL
Old Jul 11, 2013 | 02:37 PM
owslystnly's Avatar
owslystnly
My michelin PSS's are very noisy now (approaching end of life). My snow tires are quiter.
In the past, I've had a lot more than whirring/roaring noise with a bad bearing. Especially when going around corners. Also accompanied with a slight juddering.
Old Jul 11, 2013 | 02:49 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Originally Posted by unknown2k1
Good afternoon.
Thanks!
I had a front right wheel bearing go out at 17k on my '11
Old Jul 12, 2013 | 02:42 PM
unknown2k1's Avatar
unknown2k1
I am not surprised but this donkies at this dealership(not the one i bought my car from) is saying that it's the tires. So before my warranty ends, I wanna change tires and see how it goes. IF NOT, i would have to go back and b1tch but who got time for that really?
Old Oct 18, 2018 | 02:33 PM
nguyem01's Avatar
nguyem01
I got this similar noise (Roaring undercarriage) sound like when you go over the bridge, It happen at around 20 to 80 mph and not consistent.
What I replaced so far:
4 new Good Year assurance tires
New Front wheels bearing both side
New Front Pad and Rotor both side
New Front Caliper both side
And the noise still exist, I didn't replaced all the parts above just because of the noise
Any recommend what to inspect next?
2011 Infiniti G37x, 130K miles
Old Oct 18, 2018 | 02:55 PM
Mhang's Avatar
Mhang
Make sure you guys check your power steering fluid level. Mine had the same noise during start up and went away after driving for a minute. Topped off power steering fluid and the sound disappeared.
Old Oct 28, 2018 | 09:48 AM
Victory's Avatar
Victory
i had to change a front wheel bearing on my X at ~35k. Front wheel bearings on the x model are known to go. Best way to test is to take the car around some sweeping corners and see if the sound is louder turning one way vs another
Old Jan 5, 2019 | 11:03 PM
photopro's Avatar
photopro
Wheel Bearing on x
Just replaced both front at 105k for the 2nd time. Now i am getting a skip skip sound from the passenger side. Gets faster with speed, hope its not a bad replacement bearing. Bearing was put on properly removing the abs sensor each time to prevent damage. We will look at it again to see if something is obvious.
Old Jan 5, 2019 | 11:43 PM
slartibartfast's Avatar
slartibartfast
Make sure a dust shield isn't bent and contacting the wheel.
[edit]Oops, meant contacting a brake rotor.
Old Jan 7, 2019 | 11:07 AM
Baadnewsburr's Avatar
Baadnewsburr
that does sound like the dust shield got bent and is making contact, just bend it back a few mm so its not contacting any more
