Question on Sport Rotors
Old Apr 9, 2013 | 01:00 AM
noctilucous's Avatar
noctilucous
Question Question on Sport Rotors
Hey guys,
I am going to be doing an Akebono BBK upgrade on my 08 G35X sedan soon and just wanted to double check and see if this set would work as a part of what I am piecing together:
Z1 370Z / G37 Brake Upgrade Package (Sport Models)
Thanks!
Old Apr 9, 2013 | 08:15 AM
soundmike's Avatar
soundmike
Those will work with the Akebono's.
Old Apr 9, 2013 | 09:42 AM
dkmura's Avatar
dkmura
20 Year Member
Agreed- but specify the slotted rotors ONLY from Z1. Drilled rotors are known to cause stress risers in the steel rotor surface and promote cracking.
Old Apr 9, 2013 | 09:54 AM
Rad_Slinger's Avatar
Rad_Slinger
Depending how they're drilled and how they're driven. They're not gonna crack or heat up to the point to form risers if they're being daily driven.
Old Apr 9, 2013 | 01:41 PM
noctilucous
Thanks guys! I figured, just wanted to be sure. I planned on slotted as well since I live in MN and I want to avoid as much rust as possible.
Also, I assume I shouldn't be needing the extra brake fluid they have as an option correct?
SBG37
Mar 12, 2021 03:16 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
DevinKoolie
Aug 11, 2015 06:47 PM
