Help AWD Light concern
Old Feb 20, 2013 | 04:43 PM
daonlyillwiz's Avatar
daonlyillwiz
AWD Light concern
I have a question, currently contemplating on picking up a set of wheels for my 09 g37x sedan HOWEVER im worried that the size/offset might be too aggressive and light up the AWD light.
Wheels:
20x10 w/ +15 offset
tires:235-35-20
Please let advise, thanks.
Old Feb 20, 2013 | 05:07 PM
Yan141's Avatar
Yan141
I have the the same model, looking forward some input also.
Old Feb 20, 2013 | 05:12 PM
TorrentDay's Avatar
TorrentDay
Wheels:
20x10 w/ +15 offset
tires:235-35-20
You've only listed one tire size so I'm going to assume all four are equal. If that's the case you are more than fine. It's the possible difference in rolling diameter between the fronts and the rears that can cause problems with the AWD systems. If staggering the wheels, it's important to keep the rolling diameters within a certain spec (nearly identical)
The fact that you're getting bigger/wider wheels (all 4 the same size) will have absolutely NO effect on the AWD system. This will be the same situation for ALL AWD vehicles.
Old Feb 20, 2013 | 06:15 PM
daonlyillwiz
Yea all 4 are the same width. Thanks for clarifying that. I had assumed this but just wanted to make sure. Thanks.
Old Feb 20, 2013 | 07:23 PM
The wheels will be sticking out quite a bit compared to your OEM wheels.
They'll be 30mm less offset, and another 18mm for the wider rims so you're looking about 2" (48mm) further out than you are now, tires won't matter since they'll be about as wide as the rims, and like TorrentDay mentioned, diameter is just fine. If you're not lowering your X they may be outside the fenderwells.
Old Feb 21, 2013 | 10:06 AM
daonlyillwiz
Yep, im aware of how offset works, the only thing thats kinda making me worried is the fact that ill be putting increased load on the wheel bearings because of this aggressive offset
Old Feb 25, 2013 | 05:10 PM
OB G's Avatar
OB G
Damn you're going to stretch a 235 tire on a 10 inch wheel?? Can we even fit that aggressive of a setup on the front?
Manny735
Aug 14, 2017 09:25 AM
jfisher
Sep 13, 2015 07:58 AM
Rodknock
Sep 7, 2015 03:43 PM
bingpwr
Sep 4, 2015 09:44 PM
