can i run a 5mm with stock studs
They say 5mm is about the limit. The other rule of thumb is if you get about 8-9 full turns of threads on the lug. ...I searched and searched a long time on this concerned. Used a 5mm on my winter wheels for clearance all last winter with no issues.
ill let you guys know tommorrow,my wheels are due in.
If i dont need a spacer i wont run one.
i have the larger cal's and the wheel as some what of a lip.
There a 20x8.5 +35 i have a 3mm spacer alrdy That will put me at +32
If that doesnt work ill i try a 5mm,but will have to wait for them to come in.
Now that dont work ill have try a 10mm and they will be +25 and i thinks that way to much!
