stance sc5 alignment question
Old Sep 3, 2012 | 01:06 PM
Girlsare3vil's Avatar
Girlsare3vil
I put 20x10 stance sc5 20x30x275 rear and 20x30x245 in the front. I have Megan Coilover street LP. I dropped it a good amount so that the rear wheels were just slightly tucked in the fender. The guy at the alignment shop said i would have to raise it a good amount to get the alignment right because the offset will have the tires out past the fender and if I hit a hard bump it would jam the tire into the fender and buckle it... He said a camber kit would not fix this.
My question is for those who have lowered. Is there anyway I can get my car aligned but still keep the look I want and/or keep the tire tucked into the fender.?
Old Sep 3, 2012 | 01:45 PM
LegitMW's Avatar
LegitMW
Run stretched.
Old Sep 3, 2012 | 02:21 PM
Girlsare3vil
^^^ What do you mean?
Old Sep 7, 2012 | 10:39 AM
burunet's Avatar
burunet
With those tires you'll have to run negative camber so the wheels will be tucked in under the rear fender....I am on 20x10 +35 with 285/30/20 and with -2.1 camber....The camber kit will help set the camber at the best position to your liking since it has a play of +- 4
j50ny
Jul 21, 2017 10:46 AM
jfisher
Apr 25, 2017 01:22 PM
kcg37
Sep 15, 2015 11:21 AM
joshferbs
Sep 9, 2015 08:53 PM
jfisher
Sep 9, 2015 04:17 PM
