Stance SC5 20x10F +35 & 20x10.5R +27
Old Apr 22, 2012 | 02:29 PM
xeddyboi420x's Avatar
xeddyboi420x
Hey Guys,
I'm about to pick up some Stance SC5 with the below specs from another member here and I was wondering what tires I should be getting to minimize the gap w/o any rubbing issues and/or modifications.
20x10F +35
20x10.5R +27
I have a 2008 Coupe and dropped on Tanabe NF210 (.75"F & 1"R). Any opinions would help!! Thanks!!
Old Apr 22, 2012 | 02:58 PM
soolman32's Avatar
soolman32
I'd run Falken or Toyo tires in 255/35/20 F and 275/30/20 R. But with a drop as minimal as that, your semi aggressive set up will probably just look off. The only modification you can anticipate is having to trim down the rear bumper bracket a bit.
Old Apr 22, 2012 | 03:07 PM
xeddyboi420x
yea my thoughts exactly... i was thinking of going lower...
Old Apr 22, 2012 | 03:18 PM
soolman32's Avatar
soolman32
If you want it to look right you'll definitely be low. Also the Falken stretch a bit more than most. If you go with Falken I'd go with a 255 front but anything else, I'd stick with a 245.
Here's for inspiration https://www.myg37.com/forums/picture...hotoshoot.html
Old Apr 22, 2012 | 08:33 PM
xeddyboi420x
haha, that's who i'm getting the rims from!
Old Apr 22, 2012 | 08:38 PM
P Casey's Avatar
P Casey
Think u need spacer up front
Old Apr 22, 2012 | 10:02 PM
Unique Bliss's Avatar
Unique Bliss
With this setup I was told by Eric at GetYourWheels that you needed a 10mm spacer on the front. As far as tires, I was told to use 275/30/20 in the rear instead of 275/35/20. Can anyone confirm this? I am on BC Coils by the way.
Also the fronts were to be 245/35/20 for tire stretch purposes, but you guys mention 255/35/20 above. Jut looking to clarify for myself and the original post so we can both proceed with buying the setup.
Old Apr 22, 2012 | 10:06 PM
fairladyz34's Avatar
fairladyz34
275/30/20 is the correct upsize ratio. 275/35/20 is too tall
Old Apr 23, 2012 | 01:31 PM
xeddyboi420x
i was told that i wouldn't need a spacer up font because i have no BBK
Old Apr 23, 2012 | 01:44 PM
P Casey's Avatar
P Casey
Doubt u will need one then
Old Apr 23, 2012 | 02:05 PM
xeddyboi420x
So we can all agree on
Falken or Toyo tires in 255/35/20 F and 275/30/20 R?
Old Apr 23, 2012 | 02:21 PM
P Casey's Avatar
P Casey
I wouldn't run 35 series in front but that's just me. I would run 255-30 falken and 275-30 falken and regardless your gunna need to shave rear bumper bracket almost off.
Old Apr 23, 2012 | 02:28 PM
xeddyboi420x
why wouldn't you run 35? even with a drop as minimal as mine?
Old Apr 23, 2012 | 02:45 PM
P Casey's Avatar
P Casey
Raises the car up more looks uneven. You need to lower your car move to make the set up look right. IMO
Old Apr 23, 2012 | 02:55 PM
xeddyboi420x
i feel that its settled lower than what tanabe has advertised. i think i'll go with
Front
20x10+35
255x30x20
Rear
20x10.5 +27
275x30x20
and see how it looks?
