just bought new rims "stance sc-5" matte black
https://www.myg37.com/forums/picture...ml#post3366393
thats my post. i still need to get around to taking more pics but there is one pic for now
these wheels are heavy as it is, 20"s would be overkill. I used to have volks + 2 piece rotors all around which made my car feel alot quicker so i wasnt about to throw on some super heavy 20"s. also ride quality on 19"s are better and i already had tires, so just made sense
they look nice i like the white on black... the weight thing isnt that big a deal but i see what your saying that you had tires i dont blame you tires are expensive... on another note cant wait to get my headlights painted makes the car look so much more aggressive
31 lbs??? damn... 31 lbs is def over kill... thats even heavier than stock... unless youre only going for looks... brakes, braking distance, gas, take off, suffer tremendously... performance wise, 19's are the way to go...
My pleasure bro
Not bad versus stocks.
Here is some additional info for our stock 19s.
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Not bad versus stocks. Here is some additional info for our stock 19s.
Front:
Rear:
You sure about that weight on those Vossens? I weighed my stock sedan wheels in and they were 51lbs front and 57lbs rear. The vossens were 63lbs rear and 58lbs front with a 285/20/30&255/20/35 Contisport DWS that supposedly weighs 26lbs (according to their site).
Anyone know if I could run a 20x10 or even a 20x10.5 in the sc5's up front without having to roll the fenders? I'm going for the deep concaved look on all four wheels. Also, what offset tires should I go with to make it work? I'm lowered on eibachs and have a journey coupe that I plan to put the IPL body kit on. Any help will be greatly appreciated!
