Planning to lower car. help please. - newbie
Old Oct 13, 2011 | 10:25 PM
raymondd's Avatar
raymondd
i found the springs i want on ebay. They're the Tanabe NF210 Lowering springs.
Front Drop/Spring Rate: 1.0" / 7.6 kg/mm
Rear Drop/Spring Rate: 1.3" / 7.2 kg/mm
I was wondering if i need anything else to drop it? cambers? or can i just use the springs and nothing else?
sorry for asking such dumb questions.
Do i need a alignment after lowing them with the springs?
what are the step by step process for lowering a car?
can you post what springs you would recommend? 10 g37s sedan
Old Oct 13, 2011 | 11:54 PM
Midian's Avatar
Midian
It all depends how low you wanna go. your drop is going to be lower in the rear more than front logically.... but the front to me is what needs more of a drop. i went with the Eibach pro kit since its 1.2 front and 0.8 in rear looks ok.(Coupe) but sometimes i think the H&R's would have looked nice but then i would have to watch out with the roads. I didnt use any camber kit yet since my tires are still wearing out evenly but time will tell. since you have a sedan things might be different hopefully a sedan owner will chime in.
Old Oct 14, 2011 | 12:04 AM
I had the Tanabe at first. With those springs you don't need a camber kit. Give them a few days of driving to settle and then get an alignment.
Old Oct 14, 2011 | 12:18 AM
raymondd's Avatar
raymondd
okay thank you
did you like the stance with the tanabes? or any pics?
Old Oct 14, 2011 | 12:29 AM
No pics. It was a long time ago and I have gotten coilovers since. The front was still too high for my taste. If you want pics of the stance look at Tanabe's website.
Old Oct 14, 2011 | 01:29 AM
Doggy's Avatar
Doggy
IMO of you want a small drop get the eibachs
Old Oct 14, 2011 | 01:49 AM
raymondd's Avatar
raymondd
i want the lowest i can go with springs without going to camber/coilovers
any recommendations ?
Old Oct 14, 2011 | 01:57 AM
Doggy's Avatar
Doggy
What? Lol please explain
Old Oct 14, 2011 | 01:59 AM
raymondd's Avatar
raymondd
lol nvm. idk how to put it to words. but the
eibach pro springs are
Front: 1.5 in
Rear: 1.2 in
wouldn't the tanabe be better for a small drop since its 1 in the front and 1.3 in the back?
Old Oct 14, 2011 | 02:50 AM
Kuro's Avatar
Kuro
I think I understand what you are talking about OP. You want the spring that can maximum drop the car without using camber kit right? I think eibach should be the one you looking, there is tein h-tech that go lower than eibach but I'm not sure that one should get camber kit along with the spring or no.
Old Oct 14, 2011 | 03:44 AM
Doggy's Avatar
Doggy
Front: 1.5 in
Rear: 1.2 in
Im still confused on what you want, Do you want a small drop or a big drop? small drop then yes tanabe will drop it very littlle bit. If you want a large drop then look into s techs and h&r springs, You will need a camber kit though. If you get eibachs the camber isnt that bad, so camber kits arent really needed. They are if you want to get back into factory specs.
Old Oct 14, 2011 | 04:38 AM
eVitO's Avatar
eVitO
I'm running H&R's w/o a camber kit. Camber's not bad, pretty sure it's under -2.
Old Oct 14, 2011 | 11:52 AM
Doggy's Avatar
Doggy
You trippin ^ my camber on s techs is at -4 rear and -2.5 fronts
Old Oct 14, 2011 | 11:57 AM
Kidcane's Avatar
Kidcane
Florida G Club
Get the Eibachs and dont worry about the camber kit. Drive it for at least a week then go get an alignment.
You going to install yourself or pay?
Old Oct 14, 2011 | 12:23 PM
raymondd's Avatar
raymondd
I'm probably gonna get the eibachs then. and I don't want a big drop either I don't think I'm committed to driving that low. I drive a truck as a beater and I usually just run over everything. lol
@kid I'm not gonna do it myself
