Help What fluid to use with AKEBONO bbk's?
Old Mar 16, 2011 | 03:41 PM
J2S2M's Avatar
J2S2M
Arrow What fluid to use with AKEBONO bbk's?
Hello all,
I am picking up a used set of Akebono BBK's and plan to get them installed this Saturday. I just wanted to get some feedbacks from the guys w/ these BBK's.
What brake fluid are you guys using?
I was just planning picking up the OEM fluids from the dealers. I just wanted to see if there are better alternatives for the fluids.
Any help is appreciated.
-Jason
Old Mar 16, 2011 | 04:54 PM
You can buy more expensive high performance fluid like Motul RBF 600 but it will perform no better unless you are tracking your car. None. Buy any DOT 3 or 4 from the store and you'll be fine.
Old Mar 16, 2011 | 05:05 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
ON a side note, for those who have installed the akebono BBK after they got the car, will the dealer do the install and maintain the brakes warranty? I called 2 different dealers and was told one story, then the other.
Old Mar 16, 2011 | 05:09 PM
ucla bruin's Avatar
ucla bruin
Using Motul RBF 600.
__________________
Old Mar 16, 2011 | 05:11 PM
J2S2M's Avatar
J2S2M
Thanks for the info! I will be picking up some Nissan DOT 3 fluids today.
I would figure it would be a hit and miss thing. Most service advisors won't even notice them to be an added-on part since they come as OEM part on the coupes. So if you're lucky, shouldn't be a problem. However, that's one of the reasons why I waited til the end of my factory warranty period.
Old Mar 16, 2011 | 05:13 PM
J2S2M's Avatar
J2S2M
Can anyone confirm if 2 bottles is enough for a drain and fill?
Old Mar 16, 2011 | 05:50 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Werd!!!!!
Old Mar 16, 2011 | 05:59 PM
J2S2M's Avatar
J2S2M
Anyone use the regular Nissan DOT 3 fluids? That's what the dealership recommends.. I just want to know that they perform fine. Since I am getting them installed this Saturday, I don't have time to order the MOTUL fluids. No autostore carries them. It seems like they're only available online.
Old Mar 16, 2011 | 06:10 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Where u live??
Old Mar 16, 2011 | 06:13 PM
Damn Dirty Ape
Well I can do the install except for the brake bleeding.
Old Mar 16, 2011 | 06:17 PM
J2S2M's Avatar
J2S2M
Originally Posted by CEELOSG37S
Where u live??
I live in Irvine but work in GG. Do you have some extra ones I can pick up?
You're not local bro. I already schedule the install at a local shop. Charging us 250 per car which is very reasonable.
Old Mar 16, 2011 | 06:30 PM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
I don't have any but I'm pretty sure if u call Lou at Amplified Motorsport he can definitely get u some before Saturday.
Old Mar 16, 2011 | 06:42 PM
J2S2M's Avatar
J2S2M
^ Thanks for the heads up. I will definitely keep that in mind, but most likely I will just pick up some OEM fluids this time. I have absolutely no time to make the trip to AMP this week.
Old Mar 16, 2011 | 07:13 PM
Chris11LE's Avatar
Chris11LE
Castrol LMA is a good over the counter fluid (Pep Boys here on the east coast carries it, I imagine other chain stores to as well)
Friend of mine uses it in his AutoX car, so it should be good for everyday use too.
Old Mar 16, 2011 | 07:52 PM
ucla bruin's Avatar
ucla bruin
Try Ferdie at South Coast Subaru, I think he stocks RBF600.
__________________
