S-Tech ..... disappointed
Old Mar 5, 2011 | 10:54 PM
NOLA_G's Avatar
NOLA_G
I installed my S-techs today and I have to say I am disappointed with the look... I wanted the car to sit level but its much lower in the back it seems to me.... the back wheels also seem to be bowed in ... any advice?
Old Mar 5, 2011 | 11:00 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
that's called camber. when you get an alignment they will fix that to the extent possible
Old Mar 6, 2011 | 01:32 AM
Steveo47's Avatar
Steveo47
You have negative camber now, that's just the way it is till you get an alignment. They will settle after driving around for a while. Don't think they suck yet!
Old Mar 6, 2011 | 03:29 AM
G-Lover's Avatar
G-Lover
If you are running S-Techs I would highly recommend camber kits front and rear but if you are on a budget at least get rears. Most people complain about the ride with S-Techs. If you don't mind the ride then with camber kits and a proper alignment you will love them.
Old Mar 6, 2011 | 11:10 AM
NOLA_G's Avatar
NOLA_G
The camber can be fixed I'm cool with that... But what I'm worried about is the back being lower than the front!? .... What to do about that? What kind of spacers do most use?
Old Mar 6, 2011 | 11:53 AM
infamousstunna1's Avatar
infamousstunna1
The fronts should settle a little more after 2-4 weeks or so, with the extra weight up front. Total settling will depend on frequency and style of driving. After the springs finish settling...it'll even out. The gaps in the wheel well won't be perfect, but it'll be rather close. You can always get coilovers(Somewhere down the road) if it bothers you that much.
Old Mar 6, 2011 | 08:17 PM
NOLA_G's Avatar
NOLA_G
Can I buy coilovers for just back? What kind camber kit do I need ? I don't even know what that is.... ?
Old Mar 6, 2011 | 09:50 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
just go buy coilovers all around then..
STILLEN : Eibach Pro-Alignment Kit 4DR
Old Mar 9, 2011 | 03:05 AM
jjasonSU's Avatar
jjasonSU
SPC or ichiba camber kit for the rear
Old Mar 9, 2011 | 03:19 AM
P Casey's Avatar
P Casey
return em and get h&rs which sit a little lower in front but basically even, but a touch lower than s techs
Old Mar 9, 2011 | 08:39 AM
4drScreamer's Avatar
4drScreamer
That's a good question. You could obviously, but I'm not sure what impact on your ride would be. Different ride quality between springs and coils could make the driving experience fugly.
Definitely let the ride height settle and give it some time. SPC rear camber kit will require some permanent mods to your car, so if you are a lease you may want to avoid. Camber kit increases the amount of adjustment in the vertical angle of the wheels. Stock camber is minimal so after market kits are used when lowered. Although not all spring kits require more adjustment than stock allows for.
Let the springs settle. Get an alignment. And see how it looks and feels after that.
Old Mar 9, 2011 | 09:36 AM
breftayka's Avatar
breftayka
It'll end up looking good man! Don't panic just be patient. Follow the advice given and get a camber kit then an alignment when everything settles. Once your camber is corrected, your rear will raise slightly. If you are running stock wheels then get some spacers to prevent the tucked appearance. 20mm all around is a good look. I purchased the Eibach System 4 spacers which are listed for the 350Z, but work perfect in my opinion. I got 2 sets for under $200 shipped (PM for more info) They are easy to install also with no studs to replace. Other brands such as H&R and Ichiba are good too.
Old Mar 9, 2011 | 10:23 AM
P Casey's Avatar
P Casey
Aren't s techs known for sitting a little lower in the rear..regardless of what u do? That's how my buddies sits, who has spc f and r and aftermarket 19's no spacers though....?????
Old Mar 9, 2011 | 11:29 AM
myk1013's Avatar
myk1013
Yes, I've seen Gs on Stechs that look like it has 3 fat chicks in the back seats.... no spacers can fix that.
Should've gotten Eibachs man.... or coilovers.
I second the question..... can we get just coilovers for the rears?
Old Mar 9, 2011 | 12:16 PM
chuckie311's Avatar
chuckie311
im pretty sure they only come in a set...so you would have to buy all 4
