Cheap Eibach Spacers!
Old Feb 15, 2011 | 10:11 PM
breftayka's Avatar
breftayka
Auto Accessories & Aftermarket Parts at AutoAnything | Truck Accessories & Car Accessories | Floor Mats, Tonneau Covers & Car Covers
use the vehicle as a 2008 350z and search wheel spacers. It pulls up the Eibachs. The system 4 are the nut style and the ones I went with. They pull up as around $110 a pair. Enter coupon code LOYALTY on the check out screen. Free shipping + 15% off... DEAL! (I think the order must be over $150 before the discount is applied. I may be wrong though.)
I got a pair of 15mm and a pair of 20mm for $195 shipped. They also offer an OEM style spoiler painted for under $200 which I can personally vouch for. Use the coupon and its even cheaper.
Old Feb 15, 2011 | 10:49 PM
simpson_G37X's Avatar
simpson_G37X
goddamit i wish i knew about this a few weeks ago
Old Feb 16, 2011 | 01:37 AM
yogregb's Avatar
yogregb
Yes, but are they hub centric?
Old Feb 16, 2011 | 07:23 AM
breftayka's Avatar
breftayka
They are listed for the 350z.
5x114.3 CB 66.1mm
Jeb commented in the other post stating the G37 has a CB of 66.2mm, but whenever I search online it states 66.1. Can anybody shed some light?
Edit: Looking around the site, apparently some other members say it's 66.1 also.
Originally Posted by STOOF
hub bore is 66.1mm
same as 350z, g35 pretty much all nissan/infiniti.
Old Feb 17, 2011 | 12:03 AM
yogregb's Avatar
yogregb
66.1 is correct
Old Feb 17, 2011 | 12:23 AM
breftayka's Avatar
breftayka
66.1 is correct
Cool. I have found the same spacers on other sites listed for the G37, so I'm sure there won't be any problems. The prices ranged from $135-$195, and I got them on that site for about $95 a piece and then they just sent me a $10 off coupon and shipped them UPS already. Looking forward to them, but hopefully they won't cause me to rub!
Old Feb 23, 2011 | 10:02 PM
breftayka's Avatar
breftayka
Just wanted to let everyone know I got the spacers, and after two days they are great and zero vibration. Well worth it...
Old Feb 23, 2011 | 10:34 PM
xlack's Avatar
xlack
nice, thanks for the info! are these bolt-in spacers or comes with hubcentric rings? just wanna know. im about to order some!
Old Feb 23, 2011 | 10:36 PM
breftayka's Avatar
breftayka
The system 4 are nut style with hubcentric. They attach to your factory studs with nuts and then have their own studs. Ensure your wheels have channels at the back for the factory studs to "poke" into.
Old Feb 27, 2011 | 12:09 PM
OB G's Avatar
OB G
Could anyone explain to me what the difference between the system 4 vs system 5 vs system 6 stud style is?
Old Mar 3, 2011 | 08:19 AM
breftayka's Avatar
breftayka
System 4, you don't replace your wheel studs. You attach the spacer to your original wheel studs, and then attach the wheel to the studs on the spacer.
System 5 and 6 use extended studs. You remove your old studs and replace with new and longer ones and then the spacer floats between the wheel and the hub.
Old Mar 27, 2011 | 11:37 PM
platinumg35x's Avatar
platinumg35x
bumping this back up....but they don't offer the system 4 in 10mm, but they offer the system 6 in 10mm. I have nismo wheels....would the system 6 work?
Old Mar 28, 2011 | 01:03 PM
breftayka's Avatar
breftayka
System 6 is extended studs. You won't find many fasten on spacers, like the system 4, in a 10mm because the oem stud will poke so far out it will hit the rim.
Of course it will work though, you will just need to swap out the studs. This is the "preferred" way anyway. The System 4 style is just so easy to switch out.
Old Apr 7, 2011 | 06:50 AM
jujubii's Avatar
jujubii
can i get a pix of the spoiler you bought off of them?
Old Apr 7, 2011 | 10:06 PM
Dfrench200's Avatar
Dfrench200
Will these spacers work with the OEM 19" sport wheels? Thanks! Looking at the 20mm system 4.
optikol
Jan 28, 2016 07:31 PM
Kojack
Oct 9, 2015 05:53 PM
faze2988
Oct 7, 2015 12:05 AM
djdiskino
Sep 29, 2015 07:18 PM
VQCrew
Sep 26, 2015 01:19 PM
