Help Will these specs fit?
Old Jul 29, 2010 | 01:46 AM
myk1013's Avatar
myk1013
Wheel fitment guru's please chime in....
I'm looking into getting a set of 19x9.5 (+22) and 19x10.5 (+22) wheels on my G (w/ Akebono's)
Currently dropped with the Eibach ProKits. I can't go any lower.
How would these wheels fit? too agressive?
I calculated (as compared to my GT30 specs), 20x9.5 (+35) 20x10.5 (+37)
so 13mm additional in the front and 15mm in the rears??
Old Jul 29, 2010 | 02:13 AM
TomieG's Avatar
TomieG
Well it also depends on what size tire/brand u want to run. Different companies run large/true/small to their actual size.
You should be fine though with and eibach drop. I was running 19x9.5 +28 and 19x10.5+23 but i was dropped much lower (tein s-techs)
Old Jul 29, 2010 | 02:32 PM
myk1013's Avatar
myk1013
I currently have Yokohama S.Drives. 255/35 on the 9.5" front and 285/30 on the 10.5" rear wheel. I have minor rubbing issues on moderate bumps and dips.
I figured, if I have the same tire sizes on the 19's I would have about an inch of space?
Old Aug 1, 2010 | 12:15 PM
myk1013's Avatar
myk1013
*bumpers
Old Aug 1, 2010 | 12:25 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
The wheels should fit, but you'd definitely need to run smaller size tires than the 255/285 combo to prevent rubbing. Would probably want to switch to Hankooks/Generals/Toyos since their edges are a lot rounder than the Yokos.
Wheels might be sticking out a bit since the Eibachs arent too drastic of a drop. Might have to run a good amount of negative camber to pull it off but i'm pretty sure it can be done.
Old Aug 2, 2010 | 11:11 AM
Kidcane's Avatar
Kidcane
Florida G Club
"Fit" is such a subjective term these days.
2012G37
Jun 3, 2018 06:59 PM
RYs06MT
Apr 22, 2016 11:00 AM
alxmlr789
Dec 1, 2015 03:55 AM
m3clubracer
13
Sep 28, 2015 09:54 AM
