Brake pedal noise
Old Jul 16, 2010 | 06:44 PM
rskip's Avatar
rskip
Brake pedal noise
Couldn't find if anybody else had found or fixed this issue I'm having. My brake pedal makes a creaking/popping sound every once in a while. It's somewhere on the brake pedal assembly - as if something isn't tight. I had the dealership look at it and they said they didn't find anything wrong - but since then it seems to happen more often.
Cheers,
-rskip
Old Jul 30, 2010 | 11:29 AM
swizz70's Avatar
swizz70
I've only experienced a squealing when in reverse with rear breaks, seems to be very common on the S coupes! Are you sure it's from the pedal and not the actual breaks??
Old Aug 12, 2010 | 03:42 AM
hieuster's Avatar
hieuster
hey i noticed this in my car also recently. it's kinda like that sound when you apply the emergency brakes on. its tends to make the crack/popping sounds when i apply the brakes hard. i'll take it in to have it looked at on my next oil change. any updates on yours?
Old Apr 12, 2012 | 04:40 PM
plancktimeG37's Avatar
plancktimeG37
either of you guys figure out the problem?this happened once, went away and now its back and more consistent, mine is 09 sedan non sport. thanks
Old Apr 12, 2012 | 05:51 PM
joo030879's Avatar
joo030879
don't worry guys. It is just your brake pedal self adjusting height. For to compensate wear on brake pads. Otherwise as you run your pads shorter. Your pedal height will get deeper and deeper. Do following and you will find the noise gone.
1. with your engine turned off depress pedal 5 times with 2-5 seconds interval.
2. fully depress brake pedal, turn on the ignition with brake pedal fully depressed. Wait 5 seconds and let the brake pedal go. With your ignition still on wait 1 minute so your vacuum line can adjust to atmospheric pressure.
3. Turn on the ignition depress brake pedal to the floor. While brake pedal still depressed, turn off ignition. Make sure your brake pedal does not go any further down after turning your ignition off.
I know Nissan makes weird cars
The END
Old Apr 12, 2012 | 11:26 PM
plancktimeG37
.......????....ok.....will give it a try in the am;guess my pads are getting low right? Btw do I actually turn car on or just full accessory. ?
Old Apr 13, 2012 | 01:03 AM
joo030879's Avatar
joo030879
forgot you will hear a lot ok clicking sounds. That normal. And yes turn the car on.
Old Apr 13, 2012 | 07:45 PM
plancktimeG37
Gave it a try but still making sounds. Thanks for the tip though...
Old Apr 14, 2012 | 11:37 AM
joo030879's Avatar
joo030879
did your dealer check your pad?
Old Apr 16, 2012 | 08:02 PM
plancktimeG37
have not made it there yet, another 2-3 wks for oil change and i will have them take a look. every so often, i think i hear a brief squeak at very low speeds and coming to a stop; so this may be the case, though the car only hast 27.3k mls on the odo...
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
r0cketm0nkey
17
Nov 23, 2015 03:34 AM
Victory
Oct 28, 2015 01:43 PM
reachout
Sep 8, 2015 10:34 AM
