Help Nismo 370z LMGT5's Will the 10.5" rear with +23 offset fit a G37? Birmingham AL
Old Jul 1, 2010 | 02:59 PM
VossenG37S's Avatar
VossenG37S
Originally Posted by Jamaica2G
yeah, I don't like too much negative either (-3 and worse). Where's the pic? lol I wanna see!!!
oh, and the guy above is running 20's, so you have a little more sidewall to play with.
what are you
dropped on?
Old Jul 1, 2010 | 06:11 PM
myk1013's Avatar
myk1013
wow, how much does a set of these cost?
OP, could you post pics when you test fit them on a G?
Old Jul 1, 2010 | 11:21 PM
Jamaica2G's Avatar
Jamaica2G
Florida G35 Club, General Member
I threw some 245 wide tires on one front and one rear rim... I'm going to test fit on my G35 tomorrow. I need to find a local G37 for a test fit as well. I'm absolutely sure they'll look wicked on either. Yes, I said 245 - that was just because I had them laying around, I have NO intention of driving around on that haha
and when i said -3 camber, I was referring to the thought that a car with more than -3 camber in the rear looks wierd.
I have Tein mono flex's on my G35....
I'll post pix tomorrow :-)
Adrian
Old Jul 2, 2010 | 09:14 AM
Kidcane's Avatar
Kidcane
Florida G Club
There is a pic around here somewhere with those wheels on a G35 and looks pretty good. I have yet to see them on a G37 though.
Old Jul 3, 2010 | 05:07 PM
Jamaica2G's Avatar
Jamaica2G
I've seen the pix on a G35 but the guy's front fenders are 10mm wider, sooo I'll post some pix. Working on swapping out my head unit at the moment, once that is done, swapping tires tonight.
Adrian
Old Jul 4, 2010 | 12:27 PM
Jamaica2G's Avatar
Jamaica2G
EDIT: SO I made the mistake of test fitting these... I threw on two 245 wide tires solely for the test fit, so don't judge me. The fronts have on a 20mm ichicba V2 spacer.
Adrian
Old Jul 4, 2010 | 12:29 PM
VossenG37S's Avatar
VossenG37S
Nice bro looks good!!! I thought u had a g37 though lol diff offsets on 35 .
Old Jul 4, 2010 | 11:40 PM
Jamaica2G's Avatar
Jamaica2G
I see it this way... if G35's can rock +0 offset, G37's should have no trouble going +15 or so :-P +23 without the fender pull lol
I just don't have a local lowered G37 to try them on!
Old Jul 4, 2010 | 11:56 PM
Gee37S's Avatar
Gee37S
Man that looks gooood! I still think it'll be too aggressive on a G37
Old Jul 15, 2010 | 01:25 PM
w0ady's Avatar
w0ady
*in a rocky voice* adriannnnn!
Old Jul 15, 2010 | 11:23 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
crap...didn't read far enough ahead. n'm
def didn't think it would look as well as it does! Props!
Old Jul 18, 2010 | 01:13 PM
Greg Lecewicz's Avatar
Greg Lecewicz
Originally Posted by Gee37S
Here is the math that I did...
Front:
OEM G37S Wheels: 19"x8.5". Offset +43
NISMO Wheels: 19x9.5 offset +40
Since the rim is one inch wider, it will stick out half an in more (the 1 inch is split half half onto each side of the wheel). Also, since it has a lower offset, it will stick out 3mm more. So in total, the Nismo wheel will stick out 15.7mm (half an inch+3mm) more than OEM, which seems to be completely fine.
Rear:
OEM G37S Wheels: 19"x9" Offset +45
NISMO wheels: 19x10.5 Offset +23
Since the rim is 1.5 inches wider, it will stick out 0.75 inches. Difference in offset is 22mm. Combine both and the rear tire will stick out 41.05mm more than the OEM wheel, and that seems to be far too aggressive…
Does it make sense?
Perfect math! All he needs to do jackup the rear end, lower the front end and use the side exhaust pipes and a parachute like in the old hotrod days. Going lower will rub the top of the tire!
Old Jul 20, 2010 | 10:35 PM
oreoleo's Avatar
oreoleo
I did a quick chop, what do you guys think? On the g35 it looked hawt. Not too sure on the g37 though.
Old Jul 21, 2010 | 03:29 AM
  #29
Gee37S's Avatar
Gee37S
You're right, too sporty for the G...
Old Jul 21, 2010 | 03:50 AM
  #30
STOOF's Avatar
STOOF
I love those!
I can fit them no prob.
Gee37 your math is close but not quite right. I know how you got there, but its like this.
Every 1/2" = 6mm offset
So since its 1.5" wider, you knock off 18mm, 10.5 +23 is the same as 9 +5.
Im currently running 10 +17 with a 245/35/20 and neg camber. thats the same as 10.5 +23
If youre in Ft laud ill be in wpb from the 24th to the 1st if you wanna test fit.
