Uneven brake wear
Old Mar 23, 2010 | 02:31 PM
Chapinb's Avatar
Chapinb
Uneven brake wear
I just received my 30k tune up, and brakes were listed as 5-6mm all around.
1.2k miles later, I got my summer tires put on and the (independent) mechanic showed me that I have <1mm on the inside pads, still 5+ on the outside pads for each wheel!
This concerns me, as the dealer only looked at the outside pads, while Im almost working on bare metal inside. Is this type of wear normal? The dealer told me there is some alignment that can be done with the calipers, but other than that Im out of luck.
This dealer has been VERY good to me thus far, so Id like to trust them, but this just seems fishy.
Anyone else experience this type of wear? Is there a correction for it?
Thanks
Brian
Old Mar 23, 2010 | 02:47 PM
Mike's Avatar
Mike
You can always buy a set of pads and replace the inner pads only.
Uneven wear is perfectly normal, especially if you do not have a sport package; the inner pad tends to retain more heat, and the braking force is not perfectly even.
Just make sure you don't mix pad compounds (use the same pad when replacing the inner pads only).
faze2988
Oct 7, 2015 12:05 AM
Mattimus
Oct 4, 2015 01:33 PM
Irishcurtis
Sep 30, 2015 11:39 AM
John B
Sep 27, 2015 11:41 PM
VIVID
Sep 27, 2015 09:45 AM
