Help H&R or Eibach...
Old Apr 2, 2009 | 09:24 PM
  #31
gicode0823's Avatar
gicode0823
so there is no different between sports strut and regular strut?
  #32
08silver's Avatar
08silver
check this one there is more pics u can see how low it is http://www.cardomain.com/ride/3044207
Old Apr 2, 2009 | 09:25 PM
  #33
myk1013's Avatar
myk1013
Eibach ftw!!
Old Apr 2, 2009 | 09:31 PM
  #34
HamstersG's Avatar
HamstersG
Have to disagree with you just a bit. Most can get to the minimum limit (-1.83 deg) of the spec on rear camber without a kit, but if you want it more to the nominal camber setting (-1.33 deg) or closer to the max limit (-0.83) then you will need a camber kit.
Originally Posted by sTiLLBaLLiN37
A camber kit is NOT needed for Eibachs if and ONLY if you get a GOOD alignment, I was able to get mine back to specs with a GOOD alignment.
Old Apr 2, 2009 | 09:37 PM
  #35
HamstersG's Avatar
HamstersG
Really. SPC makes the ones for Eibach and I believe one other company as well, but can't recall who.
Originally Posted by jarborn1
SPC makes eibach??? Really?
I thought eibach made SPC..
Old Apr 2, 2009 | 09:39 PM
  #36
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
I mean...a little bit of negative camber isn't a bad thing!
Old Apr 2, 2009 | 09:48 PM
  #37
HamstersG's Avatar
HamstersG
Agreed especially if you go H&R or coilovers and have to tuck your tires depending on your offset. Some like it that way, but not for me.
Old Apr 2, 2009 | 09:57 PM
  #38
gicode0823's Avatar
gicode0823
In order to get the best possible alignment, either A) Take it to your dealership or B) Take it to a well known shop that has a GOOD rep
like fire stone ? I always done my alignment there.
Old Apr 2, 2009 | 09:59 PM
  #39
gicode0823's Avatar
gicode0823
I dont mind negative camber at all... unless start eating my tire
Old Apr 2, 2009 | 10:07 PM
  #40
elite's Avatar
elite
my inner tire was getting eaten up before the drop. nissan/infiniti are infamous for premature tire wear.
Old Apr 3, 2009 | 10:12 PM
  #41
gicode0823's Avatar
gicode0823
so no body has Eibach pro wheel alignment kit ?
Old Apr 4, 2009 | 07:45 AM
  #42
HamstersG's Avatar
HamstersG
I think I have seen a couple people post up that they had the Eibach one, but vast majority have the SPC. The Eibach is just rebranded SPC kit.
Old Apr 4, 2009 | 09:59 AM
  #43
gicode0823's Avatar
gicode0823
so here is quick comparison with SPC and Eibach...
SPC
Description: BRAND NEW KIT NOW AVAILABLE FOR THE G37 COUPE AND 07+ G35 SEDAN! This is the perfect kit for the lowered G. Provides plenty of adjustment for camber and comes with a larger offset toe cam to bring the toe angle back into range. Use rotary files to elongate the OE toe slots. Rear Adjustment range: Camber ±4.00 degrees, Toe ±3.00 degrees
All camber kit prices listed are for both left and right sides unless otherwise noted.
Adjustment Range (Degrees): -4.0 to +4.0
http://www.iapdirect.com/product.php?productid=42020
Eibach
Rear Fitment Note: Camber +/- 3.0.
Rear fitment. Toe +/-3.0.
I know the adjustment range are smaller compared to SPC but with Eibach pro spring should it be matter ?
Old Apr 4, 2009 | 01:12 PM
  #44
HamstersG's Avatar
HamstersG
Be a bit careful as you shop. There are two kits. One is just the toe bolts which is the picture you show. The kit you want has the arms and the toe bolts. If you are G37 Coupe then the part number you want is 72260. You can buy it here from Andy http://www.hpautoworks.com/index.php...oducts_id=4300 which a lot of us have bought from and he is less expensive than the link you posted....and he puts up with all my "has it shipped questions"....people tell me that I am impatient, but I don't have time to listen to that crap.
SPC
Eibach
Old Apr 4, 2009 | 01:45 PM
  #45
gicode0823's Avatar
gicode0823
Thanks for the info!! I will search more about it later today.
