GTSPEC Press Release Under Body Braces ** G37 Coupe/Sedan **
Old Jan 9, 2009 | 12:13 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
wow i gotta lotta -'s on my car.... 4WAS and aftermarket FI exhaust...
Old Jan 9, 2009 | 12:16 PM
GTSPEC-MARK's Avatar
GTSPEC-MARK
Originally Posted by NJlakeshoreG
yummy....on the 6 point rear brace in the middle does it come down any lower then the stock piece???
very slightly, but still above the exhaust system.
BTW, we have a chance to look under new 370Z, looks like NISSAN felt that the rear needed more reinforcement and have added a rear subframe brace for the 370Z.
The mounting points for the rear subframe tie brace on the 370Z are almost identical to the mounting points of our 6 points rear subframe for the G37.
At least we can confirm now that a rear subframe brace in deed will help since Nissan are doing it
Old Jan 9, 2009 | 12:18 PM
GTSPEC-MARK
Originally Posted by hamdavid
When are they going to be readily available? Can't believe the M-Shape will not fit some of the custom exhausts.
we went through 3 revision. Stillen and FI exhaust system piping run slightly to the right of the car. The bend that we make for the brace follows only the OEM exhaust piping which is about 2" to the left.
There is still a chance that other exhaust system which follow the OEM exhaust piping route will be able to fit the M brace, but we can't confirm it till we test more exhaust system.
There are absolute no extra room for us to make the bend bigger ...
Mark.
Old Jan 9, 2009 | 12:38 PM
bigpei's Avatar
bigpei
wadddup mark i might come through later today, beeeen sooooo busy lately!
Old Jan 9, 2009 | 12:58 PM
da mayor's Avatar
da mayor
nice more parts available!
Old Jan 9, 2009 | 03:44 PM
NJlakeshoreG's Avatar
NJlakeshoreG
Mark.
i have magnaflow and might be able to help you out if you havnt tested yet..
Old Jan 9, 2009 | 06:16 PM
SubSurface's Avatar
SubSurface
Press Release is welcme. Now we need to find out where to get our hands on these braces.
Old Jan 9, 2009 | 06:28 PM
NJlakeshoreG
mark forgot to add...alot of us are having problems with HFC and aftermarket exhausts...where the oem cross brace is it hits the exhaust ever so slightly bc it hangs a lil lower...if this cross brace is jsut that lil bit low enuff this could be a GREAT thing for all of us!!!!
Old Jan 9, 2009 | 10:31 PM
HamstersG's Avatar
HamstersG
One more questions
Mark,
So can you tell us when the new stuff will be generally available?
Also, I appreciate the information regarding the issue with M-Brace and after-market exhausts. So in looking at the pictures you posted, it appears any axle-back exhaust would be good.
One last question. It appears that the 6-point brace comes in 3 pieces? I want to know if the largest piece would fit in a 3' x 3' x 3' cube which is the size of my powercoater's oven?
Mark.
Old Jan 10, 2009 | 11:49 AM
Ivoidwarranties's Avatar
Ivoidwarranties
Do these come powder coated or painted?
Old Jan 10, 2009 | 12:35 PM
mpbruin108's Avatar
mpbruin108
okay, i understand the purpose of all these braces except the fender brace. What is that for really? I got the front and rear but I don't do any track...do these other braces really add anything more?
Old Jan 10, 2009 | 01:12 PM
NJlakeshoreG
well i know 350z's that track use the fender braces...im imagining they really tighten up top of frame to bottom of frame...
not 100% sure tho..
Old Jan 21, 2009 | 02:54 PM
GTSPEC-MARK
No, it's painted with our custom color. It's actually a mixture of blue and grey combined. Color changes at different angle. We do have to bake the braces after painting because of the color effect / properties.
We also apply triple layers of paint for the best result.
Old Jan 21, 2009 | 02:58 PM
  #29
GTSPEC-MARK
It's hard to measure what each brace will do in performance wise. Most of these brace were designed based on our past experiences with other vehicles and also our engineer's past experiences.
One of our engineer that we hired over sea has 10+ years in racing and R&D with top race team in Japan.
The fender brace and trunk cage were braces that was used in his team.
Old Jan 21, 2009 | 03:20 PM
  #30
finagle69's Avatar
finagle69
should say 08+ Infiniti G37...
