will these rim sizes work for a g37coupe?
Old Apr 9, 2008 | 03:56 PM
nyckid's Avatar
nyckid
19x9.5 +28 offset (FRONT)
19x10.5 +23 offset (REAR)
will i be able to fit in a BBK with this on a g37 coupe? I plan on swapping the wheels from my g35 to g37 if i decide to get one in the future...
Old Apr 9, 2008 | 04:29 PM
Kidcane's Avatar
Kidcane
Florida G Club
Brakes may just barely clear but I think you are going to stick out in the front and rear with those offsets.
Old Apr 9, 2008 | 04:46 PM
nyckid's Avatar
nyckid
hrmm so you're saying it may stick out? Cause ive seen that setup on a g35 and its flushed... unless the body of the g37 coupe is not as wide as the g35 then i dont see why it would stick out.
Old Apr 9, 2008 | 04:51 PM
GiGGaplease's Avatar
GiGGaplease
i have +55 9.5 in the front and it does not fit. will get a 25mm spacer, so i think its going to fit. i test fitted and it will stick out about half inch. you rear will stick out about 1/2-1 inch. mines sticks out around there.
Old Apr 9, 2008 | 04:56 PM
Kidcane's Avatar
Kidcane
Florida G Club
I promise you it is a different set up. If you dont believe me then good luck trying and post pics if you get them on. I have my Maya STM from my G35. They are 19x9 with 30 offset and 19x10.5 with 29 offset and they are close as you can get without sticking out and I had to dial in the camber, adjust the tow, remove all the liner and tabs in my wheelwell and they still rub just a tad when I hit a big bump. It took me a week to get the fitment right and yours are more aggressive.
Old Apr 9, 2008 | 04:59 PM
TerribleONE453's Avatar
TerribleONE453
yupp... no way those rears are gonna fit.
Old Apr 9, 2008 | 06:22 PM
GiGGaplease
kid, that is sick. the drop and offset is perfect. nyc, your rear will fit, but if you want to drop it, they will rub.
Old Apr 9, 2008 | 06:28 PM
TerribleONE453
i bet they will rub without being dropped... since the suspension is so soft on our cars
Old Apr 9, 2008 | 06:29 PM
GiGGaplease
they probably wouldnt. i will find out in a week or so when my tires comes in. we have about 2 inches clearance with the stock tires, so aftermarket rims and tires, probably would not rub.
Old Apr 9, 2008 | 06:30 PM
TerribleONE453
what are your offsets gonna be...? sorry if you already posted that
Old Apr 9, 2008 | 06:31 PM
GiGGaplease
nyc's offset is 28 front and 23 rear
Old Apr 9, 2008 | 06:32 PM
symalik's Avatar
symalik
The fronts MIGHT work i think but the rears will stick out for sure. I have 20x10.5 with +35 in the rear and I barely clear with some negative camber.
GiGGaplease
or you was talking about me? mines is +55 front and +30 rear. will get spacers so the front would be +30 also.
Old Apr 9, 2008 | 06:34 PM
TerribleONE453
his offset is even lower than your rear...
Old Apr 10, 2008 | 11:30 AM
nyckid's Avatar
nyckid
weird, damn... so what offsets will work well on a g37 coupe then? im so use to offsets around +22 to +25
