I was told not to do this as the G35 springs were intended for hte weight of the G35 not the G37. I think it is safer to wait, unless you must have your car lowered for some reason.
I'm not sure if additonal 36Lb/corner makes big difference in height using lowering springs intended for G35. Basically G37 is about 144Lb havier than G35 which distributed on all four coners unless the weight ration between the front and rear has been significantly revised from G35.
G35:3524LB
G37:3668LB
Delta: 144Lb (36Lb/corner)
I'm still considering the Tein S.Tech spring which may not be too bad.
about time...the rear looks wierd? did you cutt anything or something for it to sit like that? cause i had Tein S-tech's and Tein Flex Coilovers on my Old G35 and it never sat that low?
tats pretty slammed.
I like the tuck. i always tucked my wheels when i drop my cars. especially the rear. Seems liek u have a negative camber too already.
the rear does tuck but the body line of the car has a slight rake so the front does sit a little lower then the rear but the way the rear fender is cut it makes the rears tuck. the ride quality is still good no problems at all.
