Looking for lowering springs for G37
Old Oct 10, 2007 | 01:54 AM
Blk-G35's Avatar
Blk-G35
Are there any company released lowering spirng for our car yet.
Old Oct 10, 2007 | 02:39 AM
terrycs's Avatar
terrycs
Eibach should be out by the end of the month.
Old Oct 23, 2007 | 06:28 AM
kiddmaff5646's Avatar
kiddmaff5646
H&R has them already
http://www.stillen.com/product.asp?i...odel=G37%202DR
Old Oct 23, 2007 | 11:00 AM
solopresident's Avatar
solopresident
they are not out yet. The part # is just up.
Old Nov 10, 2007 | 01:57 AM
Blk-G35's Avatar
Blk-G35
1.5" ~ 2.0" drop is just too much and I was thinking about 1" or so to maintain stock ride feel. Will 1" drop still requires the camber kit?
Old Nov 10, 2007 | 11:05 AM
terrycs's Avatar
terrycs
Check this out:
https://www.myg37.com/forums/brakes-and-suspension/175172-eibach-pro-kit-done.html
Old Nov 10, 2007 | 11:13 AM
vinnys coupe's Avatar
vinnys coupe
try getting in touch with unv-it46.. he is selling them for 200 bucks and he has a pic of his car droped
Old Nov 10, 2007 | 08:28 PM
UNV-IT46's Avatar
UNV-IT46
I'm not selling the pro kit. I am selling the tein S techs for the G35. I will end up selling the pro kit when they are officially released...
Old Nov 11, 2007 | 10:40 PM
Blk-G35's Avatar
Blk-G35
Originally Posted by terrycs
Thanks for your info Terrycs and I'll definetely like to get same spring swap on my G37 with 10mm spacer if possible. BTW, I'm not too familier with wheel spacer but does longer stud needed for 10mm spacer for G37. What would be the maximum spacer thickness without changing the studs.
Thanks
Old Nov 14, 2007 | 11:58 PM
terrycs's Avatar
terrycs
I would go with new lug bolts for 10mm spacer. Just get new lug bolts that are 10mm longer than stock.
Thanks
Old Nov 18, 2007 | 02:34 PM
Darkvader's Avatar
Darkvader
You can use G35 springs it works.
Old Nov 26, 2007 | 01:14 AM
TerribleONE453's Avatar
TerribleONE453
im thinking about ordering the elbach pro kit off stillen.. where would i pick up the camber kit?
Old Nov 26, 2007 | 01:53 AM
terrycs's Avatar
terrycs
Stillen should also have them once they are available. There are other places as well.
Old Jan 6, 2008 | 12:53 AM
RedG37SNC's Avatar
RedG37SNC
Tanabe has some mild Springs available for the G37, 1.0/.07. I like the low tone of the Exhaust as well.
http://www.tanabe-usa.com/springs/nf210.asp
The NF210 coil spring features a tasteful drop, and produces the best overall ride quality and comfort for a performance lowering spring. The lowered stance of the NF210 gives the car an elegant pose, while the spring rates, which are only slightly raised (up to 5% over stock) retain factory ride quality settings.
This coil spring is extremely popular with luxury tuned vehicles, as well as those with larger diameter wheels that want to eliminate fender gap, but maintain excellent driveability while reducing the risk of damage to wheels that is associated with stiffer suspensions.
Comfort especially important on daily driven vehicles, and their passengers. The NF210 provides the best driving experience for all types of roads.
Old Jan 6, 2008 | 12:56 AM
GiGGaplease's Avatar
GiGGaplease
i want around 1.6 front and 1.2 rear. any springs will come close to those specs?
