Brand new drilled and slotted rotors and pads making weird noise
Old May 10, 2022 | 12:46 AM
Klaus_2003's Avatar
Klaus_2003
Hello, I recently upgraded my rotors and pads to drilled and slotted and ceramic pads. My mechanic did the bending process for me and said I was good to go. A day later, I noticed this weird sound when coming to a stop; it’s hard to explain. A video has been provided below! Please let me know what’s going on.
File Type: mov
Old May 10, 2022 | 01:23 AM
Birdie's Avatar
Birdie
What side or wheel is it coming from? It could possibly be a cv axel starting to go bad. Or he could of possible forgot to put some of the hardware in correctly. Can you jack you the car and turn one wheel at a time or is the sound only there when applying brake pressure?
Old May 10, 2022 | 01:31 AM
Klaus_2003's Avatar
Klaus_2003
the sound is only there when I apply pressure on the brakes. If I press them hard enough sometimes the sound goes away. It sounds like it’s coming from the front left wheel. The sound only starts after driving for a bit, initially when I first start driving and braking it’s not there, but it’s starts after driving for a bit.
Old Sep 20, 2022 | 03:08 PM
RichardBegay's Avatar
RichardBegay
I want to help you but I don't have much knowledge about it. Do you want to upgrade your CV? But you are searching for the best cv creator company for that. I will recommend you the best company, click here. You can check the post through this link. And get your cv written by professional writers.
Old Dec 4, 2022 | 09:46 AM
Kman5's Avatar
Kman5
I had a click type noise when turning to the left @ low speeds when I had my G37. The clicking was more pronounced than the audio in your video though. I was able to narrow it down to the passenger side CV Axle. I could hit it with my palm and feel/hear the difference from that of the driver side. The boot wasn't fully sealed and was letting in dirt/grime. Is the sound worse when turning @ low speeds or only when braking?
triippy
Jun 4, 2016 10:06 PM
warped ideas
Jan 26, 2016 07:05 PM
daonlyillwiz
Jun 2, 2015 06:10 PM
2009G37Bandit
Aug 23, 2012 05:20 PM
