Help me confirm rotor size?
Old Mar 13, 2020 | 04:34 PM
crazyone's Avatar
crazyone
Hi
I'm having a hard time confirming the rotor size online.
Does anyone know?
2014 Q60S awd
Front and Rear
Thanks,
Dan
Old Mar 13, 2020 | 04:52 PM
RMB5190's Avatar
RMB5190
I believe it's the same as the G37x:
320mmF///307mmR
Old Mar 13, 2020 | 04:57 PM
I thought the G37xS Coupe (Q60S AWD) came with the BBK just like the RWD Sport Package?
Old Mar 13, 2020 | 06:20 PM
RMB5190's Avatar
RMB5190
I was under the impression the BBK only applied to the sport RWD 6 MT/7AT models; for all AWD trims, the "S" was just a appearance package. I could be wrong -- OP, pop off a wheel and measure; that is the safest way to confirm.
Old Mar 13, 2020 | 06:47 PM
The Sedan, yes, but not the Coupe. Pretty sure the Sport Package for the Coupe came with 14.0" front rotors and 13.8" rears as part of the Akebono BBK, regardless RWD or AWD. He doesn't need to remove a wheel and measure things... there were only two sets of OEM rotors: sport and non-sport.
This should be a pretty simple answer from someone here in the Coupe forum.
Old Mar 13, 2020 | 08:09 PM
crazyone's Avatar
crazyone
Thank you for the quick replies,
I could only find information for the Q60, none mention Q60S,
check this out: https://www.walmart.ca/en/ip/Max-Fro...RD2U53JNMMS8YS
Old Mar 13, 2020 | 08:17 PM
Shop tirerack for OEM replacement rotors... not Walmart.
Old Mar 13, 2020 | 08:28 PM
crazyone's Avatar
crazyone
Not buying from walmart, just sharing the numbers:
Fits: 2014 2015 Infiniti Q60 355mm Front Rotors and 330mm Rear Rotors
And a different site saying 355 front 350 rear
Old Mar 15, 2020 | 08:07 PM
mummy2's Avatar
mummy2
Walmart sells the same stuff Tirerack does, sometimes, and you can do in-store returns. So Walmart is better than Tirerack in that regard.
Old Mar 15, 2020 | 08:11 PM
mummy2's Avatar
mummy2
Scroll down to specs. https://cdn.dealereprocess.org/cdn/b...4-q60coupe.pdf
Old Mar 15, 2020 | 10:38 PM
crazyone's Avatar
crazyone
Thank you!
Sport is 14" front and 13.8" rear (355mm and 350mm)
Non Sport is 13" around. (330mm)
celwin
General Tech Questions
May 1, 2018 12:10 PM
REDg37vx2
Jul 21, 2014 08:48 PM
rAiN
Jul 11, 2009 04:16 PM
